Originally Posted by ssbundy
Quick update... just came back from our trip and everything worked great. Only problem I had was I bought a surge protector thinking it would help ( https://www.campingworld.com/southwi...amp-73995.html) but when I used it I would lose power after about 10 minutes. Also when I plugged it in and I was at my water hookup if I touched the door and then the water supply at the park I got zapped. If I removed it everything worked fine and no more shock so I think the surge protector is bad... anyone have any recommendations for a better one?
That device is only a surge protector. MUCH better is an Electronics System Monitor that also protects against low voltage (brownouts) which are much more prevalent and damaging to your electronics.
We have a hard wired Progressive Industries model PI EMS HW50C, but they also make a plug in version too.
PS, it sounds like yorus has the neutral and ground crossed,
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
