Originally Posted by NO3putt
Sounds like too much, we may lose that amount in a year. We put Pro-fill battery watering system on the batteries and it makes it so easy to fill to the proper level.
I have a watering system too. And I also added the optional Magnum control panel to better monitor and change parameters in the inverter/charger.
I cut the charge rate down to 50% and it did stop the out-gassing and liquid on top of the batts, which was really bad at first.
Maybe I need to lower it some more. The new control panel display will show zero amps a good bit of the time; which I assume means that no charging is going on. It's almost always in float mode too.
If I need to cut the charge rate even more, to stop the boil off completely, then I'd say my Magnum is really out of adjustment.
Thanks all. Sure glad I have all these issues; give me something to keep me busy, off the streets and out of trouble.
Boowho??
