Old 06-17-2017, 09:45 PM   #1
ernest917's Avatar
Inverter Compartment Fan
Is there an on/off switch for the fan in the inverter compartment or is it automatic?? Mine has been running for a few days.... Of course it also been in the mid-90's with bright sun as well....
ernest917 is offline   Reply With Quote
Old 06-17-2017, 09:58 PM   #2
Bluepill's Avatar
If it is an Inverter/Converter/Charger combo, the fan is automatic.
Bluepill is offline   Reply With Quote
Old 06-17-2017, 10:08 PM   #3
ernest917's Avatar
Thought it was.... Guess it'll eventually shut off....
Old 06-17-2017, 10:44 PM   #4
You should check your batteries. Could be running cause it is at max charge rate due to a dead or bad battery.
bigmurph is offline   Reply With Quote
fan, inverter
