How does one reset the leg distance, trip distance to zero? The Freightliner manual tells me to use the right side steering wheel buttons. The right side buttons control the wipers and do not control the display. Such may apply to other chassis.
2017 Berkshire XL 40A & 2017 Ford Focus SE
I Built and Fly - Van's Aircraft RV-12
Ham Radio - W9EAA
Unless things have changed drastically, there is a small, square button somewhere on the left sided of the console. If you have the key in the on position, hold the button to the right for several seconds. You should then see a 'set up' (I think that is the wording) on the LBCU. From there you can get to the leg distance, date time and several other items that can be reset. http://www.rvtechlibrary.com/electro...bcu_owners.pdf
Tom and Margaret
2014 Berkshire 390bh-60
Thanks. Figured it out. After selecting a trip parameter, I had to left click and then an option is offered to zero the trip parameters. Did not have to go to setup. Thanks again.
Ham Radio - W9EAA
