Old 11-25-2020, 10:34 PM   #1
lost power to part of the coach
I got a Forest River 38A, Class A
Had the washer/dryer running, the microwave, and one AC. sounded like a I blew a breaker, lost my lights, the touch screen control panel. none of the switches by the exit door work, and the "house disconnect" button by the front door will not work.
The Washer/dryer, microwave, refrigerator, plugs all still work. I have a surge protector and it says the wiring is correct, the shore power light is on for the Auto transfer switch and the batteries are still charging.
None of the breaker are flipped, I turned them all on and off. I cant see any fuses that look to be out, although the digital screen in the fuse box is not working so I only did a manual check.
Not sure if there is any other breaker box or something like that, that I may a have flipped.
Thanks for any suggestions you may have.
Saner is offline   Reply With Quote
Old 11-26-2020, 05:04 AM   #2
wmtire's Avatar
Hmm it seems like everything inoperational is 12 volt DC. You would think that these items would work off the battery if something happened to the 120 volt AC (the converter).
We have a berkshire rep on the forums who may can help but it being Thanksgiving, they as well as other members may not be on the forums to read this.
2011 Flagstaff 831 RLBSS
I want to go to Bora-Bora, but Iím too Pora-Pora.
Old 11-26-2020, 09:22 AM   #3
It might help those with similar model coaches help you if you let us know what year your coach is. In our coach, there are several large breakers mounted on the walls of the battery bay. You might check those to see if one tripped for some reason. On ours, an "arm" on the top of the breaker pops up when tripped - just push it down to reset.
I have found that none of the 12v systems work if the house batteries are disconnected (either through a tripped breaker or the battery cut-off switch in the bay), even if connected to shore power.
Ty & Deb Montag
2020 Berkshire XLT 45A
2021 Jeep Gladiator
anaviator is offline   Reply With Quote
Old 11-26-2020, 09:33 AM   #4
Mmnsc's Avatar
Check the inverter/charger which has a reset button. Press the button (I believe it is red ) it reset the inverter.
I hope this works for you. Good luck
Mmnsc is offline   Reply With Quote
Old 11-26-2020, 09:59 AM   #5
Did you mean the converter/charger? An inverter would supply 120v AC power, but itís the 12 volt items that are apparently inoperative.
2020 Sunseeker 2440DS on 2019 Ford E-450, Trekker cap, Topaz paint
BehindBars is offline   Reply With Quote
Old 11-26-2020, 11:10 AM   #6
Mmnsc's Avatar
There is a large fuse 125 amp in the battery compartment that may be blown. Depending on the coach there may be more than one and/or a higher amperage. That is for the battery system.
Old 11-26-2020, 11:32 AM   #7
Tech Support
Also, Forest River has a great tech support line. (Might be closed for the holidays, though.) They are helpful and enthusiastic. 574.642.2640.
Tom 2424 is offline   Reply With Quote
Old 11-26-2020, 12:29 PM   #8
Maingler's Avatar
We you running generator or on shore power?
Maingler is offline   Reply With Quote
Old 11-26-2020, 12:30 PM   #9
Maingler's Avatar
This may help diagnose. Berkshire RV Power Presentation (1).pdf
Old 11-26-2020, 04:37 PM   #10
Check pedestal breaker if you are on shore power
Harkerr is offline   Reply With Quote
Old 11-27-2020, 08:19 AM   #11
The year is a 2018, "38A"
Old 11-27-2020, 08:25 AM   #12
I running off the shore power.
Old 11-27-2020, 06:53 PM   #13
Exclamation
this is nothing to do with 120v shore power, it is all 12v related, which is your BATTERIES, and the wiring to and from them to all your 12v lights, fans, and other systems that have to do with 12v power, or even those that 'control' 120v appliances, like the air conditioner, with 12v power thru the Thermostat.
it's likely you tripped the Main Buss Fuse/Breaker within your battery compartment, which controls all your power between the Battery bank and your fuse panel. Find the Buss Fuse/Breaker located probably on the wall near the batteries, where a little yellow 'flag' might be poking out - push it back in...
The Turners...
formerFR is offline   Reply With Quote
Old 12-01-2020, 10:20 AM   #14
Commercial Member
Saner,
IS the inverter on? If so does the MRC50 panel show a red fault light? try resetting the inverter, there is a push button on the back of the inverter, push and hold that button in and the green ready light will strobe identifying that the inverter is being reset. also on the side of the inverter is a push button circuit breaker, push it in and it should reset.
Lincman983 is offline   Reply With Quote
Old 12-04-2020, 08:52 AM   #15
150A Mega Fuse
Check the 150A/12V Breaker located in the House Battery Compartment.
(See Attached pic)
red0801 is offline   Reply With Quote
Old 12-06-2020, 07:40 AM   #16
Originally Posted by Maingler View Post
This may help diagnose. Attachment 243679
This is a great powerpoint showing the basics. I saved it for future distribution to people that are having issues. It will save me a lot of typing.
ercjr110165 is offline   Reply With Quote
power
