Old 08-13-2020, 03:24 AM   #1
ernest917's Avatar
Loud water pump
Suggestions on how to hush a water pump....
My new one is LOUD!!!!
ernest917 is offline   Reply With Quote
Old 08-13-2020, 09:37 AM   #2
edgewant's Avatar
My REMCO is a little loud too. But it has a higher flow rating than the Shurflo that came with the motorhome.
All in all like the REMCO better. I just made sure it wasnít sitting against anything and looped the inlet line like is suggested. Sorry I donít have any better recommendations.
edgewant
2013 Berkshire 390RB-60
toad - 2002 Jeep Wrangler Sport
edgewant is offline   Reply With Quote
Old 08-13-2020, 10:37 AM   #3
Just as confused as you
Scrapper's Avatar
Have you made sure the rubber vibration isolators are in place and tightened down? There should be one on each corner of the pumps mounting plate. Also check for the pex tube resting on a wall or panel. They are thin so any vibration in the tubing will be amplified.
Name:	Vibration Isolator 2.jpg
Richard & Jill
Camping since 1989, seasonal since 2000
I deserve hazard pay when camping with my relatives.
Old 08-13-2020, 11:06 AM   #4
Check to see if it is mounted to a thin sheet of wood. If is, remount to a thicker board and glue the new board to the floor and a few screws.
Thomas ho is offline   Reply With Quote
Old 08-13-2020, 11:56 PM   #5
ernest917's Avatar
Vibration isolators??? I donít believe it has those..... I believe itís mounted directly to the compartment floor.....
Iím considering putting a rubber pad under it....
Old 08-14-2020, 06:34 AM   #6
...far N Georgia!
formerFR's Avatar
I use a silicone 'doggy bowl', which happens to work perfectly - it keeps the water pump off the floor, and it's basically 'floating' on the silicone 'bowl' so that none of it actually touches the coach.
now, my problem is, though, I CAN'T hear it!
The Turners...
'14 Thor Palazzo 33.3 compact diesel 100k+miles since '14... US, Alaska, Canada...
AND a '14 Gulfstream Amerlite
AND a '07 ForestRIver Rockwood : )
formerFR is offline   Reply With Quote
Old 08-14-2020, 10:16 AM   #7
ernest917's Avatar
Picture???
Old 08-14-2020, 11:06 AM   #8
often times it's the PEX tubing vibrating against a wall or floor. Look at it when it's running and see if that is it, if so add a looped flexible line between the pump and PEX. You can buy them at Home Depot, used to connect the water to toilet or sink.
nayther is offline   Reply With Quote
Old 08-17-2020, 03:14 PM   #9
RKNOLA's Avatar
Rick used a piece of horse stall mat (https://www.tractorsupply.com/tsc/pr...bber-stall-mat ) that he bought to put under the tires. He cut a square, placed water pump on top of mat, screwed pump to mat, then used separate screws to screw mat to compartment floor.
Rick and Karen
2018 Berkshire XL 40C
2011 Honda CR-V toad FB
RKNOLA is offline   Reply With Quote
pump, water, water pump
