Old 06-04-2016, 01:54 PM   #1
Macerator Pump
I'm thinking of buying a macerator pump does anyone use one. I'd like some input from anyone. Ease of use how far it will pump what type of discharge hose and what ever else I may need to know. Thanks Jim
jrlebaron is offline   Reply With Quote
Old 06-04-2016, 02:04 PM   #2
Macerator pump
I have a sewer port in the rear of my lot. Total pump out distance is about 130 feet. I have had no problems pumping at this distance.
Emery
skeet25golf is offline   Reply With Quote
Old 06-04-2016, 02:25 PM   #3
rogo's Avatar
I have the portable FloJet Macerator pump that attaches to the TT black/gray discharge hookup. I use it at home with a 75' 3/4" hose to empty and clean tanks following a trip. Hose attaches to an outside septic tank clean out. Works very well for that purpose.
I found that it was a bit noisy and took too long to use at a campsite, so I don't take it with me anymore. Emptying with the regular slinky is quiet and fast. Macerator would be advantageous, however, if you encounter a site with an uphill run for your sewer hose.
I installed a waterproof 12V receptacle on the TT just above the discharge hookup and a marine plug on the Macerator for convenience.
Roger, Sherrill, and Harley (Great Dane)
2016 Flagstaff V-Lite 30WRLIKS [sold]
2012 F-150 XLT Screw 3.5L EB, 3.55
Air Lift AirCells, Blue Ox BX1500
rogo is offline   Reply With Quote
Old 06-13-2016, 06:24 AM   #4
Rogo thanks for the info I purchased the same one will connect it today hope it does the job. Jim
Old 06-13-2016, 07:06 AM   #5
KennyGolub's Avatar
I also have the flowjet portable. I use a 3/4" hose and run it 125 feet to my septic system. It works great. On longer trips, the rest room facilities are often used. Since I have this, I no longer have to worry about a partially filled tank sitting in the yard for any length of time.
It's also great if I want to take my time and do a thorough flushing/cleaning of the tank.
You won't be sorry.
Ken & Laurie
2022 Riverstone Legacy 39RKFB
2022 RAM 3500 Laramie Dually
KennyGolub is offline   Reply With Quote
Old 06-13-2016, 07:19 AM   #6
We can use this one at Home,bastard Campsites,or Small Forest Fires! It will flat pump some Liquid! Discharge side is 5/8 GH! Youroo!! PS this unit will also handle: "Corn cobs and Any type of Toilet Paper"!
ID:	110984   Click image for larger version
Old 06-13-2016, 07:20 AM   #7
klucas's Avatar
I too use it at home to dump in the sewer. I had it connected to the berk for use all the time. However, I found it to be a pain at campgrounds. It's very slow to drain and the macerator clogs easy.
klucas is offline   Reply With Quote
Old 06-13-2016, 09:04 AM   #8
CAT-RN's Avatar
And how does one unclog it. This don't sound good?
Russell
CAT-RN is offline   Reply With Quote
Old 06-13-2016, 09:38 AM   #9
armye7's Avatar
We have one on our Entegra bus, and we love it. No mess takes a little longer to dump but no mess.
armye7 is offline   Reply With Quote
Old 06-13-2016, 10:06 AM   #10
klucas's Avatar
Russell
It's not fun!! The blades can get clogged with hair ect. When that happened to me I had to close the tanks then remove the macerator connection. Yes it was full and under a little pressure👎. Once removed I had to remove the blade assembly, clean and reinstall. I removed it soon after that. I found not only the clogging issue but it took a while to dump a full tank. I only use it on return trips home for a final dump before storage.
Old 06-13-2016, 10:19 AM   #11
Jim check out Rich's post. He just did a nice install. I know he HS been researching this item for a good while. I would bet he did it right and found the best unit at the best price.
Old 06-13-2016, 10:21 AM   #12
http://www.forestriverforums.com/for...d.php?t=110630
Old 06-13-2016, 10:25 AM   #13
BamaBob's Avatar
YouRoo - what brand do you have? Has it ever clogged? (Doubtful if you are grinding up corn cobs LOL)
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
BamaBob is offline   Reply With Quote
Old 06-13-2016, 02:17 PM   #14
The maserator needs to be connected to 12v where or how did one connect this.
Old 06-13-2016, 02:43 PM   #15
Restcure's Avatar
Some wire in a 12v connector near the sewer lines; I made a line to run off the trailer's 7-pin connector.
I also bought a clear elbow to go between the macerator pump (aka poop cannon) and the drain so I can tell when the tank is clean. Yes, ew, but very useful.
A note about the backflush port. It will...
  • allow you to push clear water into the tank to help flush more of the solids out
  • allow you to clean out the hose between the poop cannon and the sewer point
  • make you think, for a moment, that your tank is sparkling clean (until the water starts to murk up again)
It is NOT a tank rinser. If something is stuck in the tank the flush port will probably not remove it. The best way I've found to do that is occasional use of a spray wand directly down the toilet (and regular use of the Geo Method.
2012 Rockwood Ultra-Lite 2701SS, Goodyear Endurance LRD, ProPride 3P 1400 hitch
2013 F-150 FX4 7700# GVWR SuperCrew 3.5L EcoBoost 157" WB Max Tow 3.73:1
John, Dawn and Emily... and Bella the camping kitty
visit our website at www.restcure.ca
Restcure is offline   Reply With Quote
Old 06-13-2016, 03:49 PM   #16
tmmar's Avatar
JD,
Can't use a spray wand in a Berkshire. The drain pipe goes down may 4" and makes a sharp bend toward the tank. But, we do have built in black tank flushes.
Tom and Margaret
2014 Berkshire 390bh-60
Old 06-14-2016, 11:29 AM   #17
Kitchen Aid 3/4 HP 120V Yes it is great for RV use,anything a Person has eaten and discharged into the Tanks this unit will handel! In its Prior Life in the House it did grind up "Corn Cobs and Bones" so I have Complete Confidence that it will Dispose of "Normal" black tank contents! Youroo!! PS There will NOT be Pics. of Unit in "Action"!
Old 06-14-2016, 12:50 PM   #18
BamaBob's Avatar
You know, that is wizard YouRoo! I wonder why these $300-400 macerator pumps are not based on a garbage disposal?!
Old 06-14-2016, 01:02 PM   #19
Restcure's Avatar
Originally Posted by tmmar View Post
JD,
Ahhh.... how about a flexible spray wand?
Old 06-14-2016, 01:05 PM   #20
BamaBob's Avatar
But, like Tom says, we don't need them - the black tank flush works perfectly.
pump
