Old 10-20-2021, 06:01 PM   #1
Multiplex system screen not lit
My screen is dead. Everything else that has its own switch is fine. Coach batteries are great, 13.1V. Anyway to re set the system, turn it on and off etc? I need my coach in my driveway to work. Friends staying in it for a wedding. Suggestions wanted..thanks
2019 Berkshire XLT 45B
I think it is precision plex screen.........
2019 JLR toad
2019 Berk 45B
zb39 is offline   Reply With Quote
Old 10-20-2021, 06:36 PM   #2
doing more research . Where is my precisionplex fuse panel? All 4 slides are in. This is a bummer.
2019 JLR toad
2019 Berk 45B
Old 10-20-2021, 07:19 PM   #3
The Wanderer2's Avatar
Pull the screen from the wall and unplug it from the back. After a couple minutes plug it back in and see if it reboots. If not, call Daniel Dinovo Technical Support Precision Circuit Inc. at (603) 515-9100 ext-704. I had the same problem and he sent me a new screen after trouble shooting the problem.
2019 Berkshire 34QS
2020 Grand Cherokee Summit
The Wanderer2 is offline   Reply With Quote
Old 10-20-2021, 07:35 PM   #4
The fuses and main Precision Circuit unit is on the lower right side of the bed. Daniel will have you run some test from that main unit before he sends you a new screen. The replacement screen was free but I paid to have it sent overnight. This happen to me last year just before a 3 week trip. After talking to Daniel, I was up and running the next day. Good luck!
2019 Berkshire 34QS
Old 10-20-2021, 08:15 PM   #5
*Precision Plex screen goes dead.
Turns out there is a small battery behind the PrecisionPlex screen that was dead and wasn't telling the LCD screen to "wake up" after the coach batteries were brought back to life. *The battery is a CR1025
This is a quote from another post. Find the battery and replace. Sounds like your problem.
18 Berkshire 34QS, 2018 Jeep Cherokee.
btritschler1437 is offline   Reply With Quote
Old 10-21-2021, 07:39 AM   #6
Commercial Member
Have you tried turning the battery disconnect off by the entry door and leaving it off for about 90 secs and powering it back on? If that doesn't work it could then it could be the little battery in the touch pad or possible fault in the touch pad itself
Lincman983 is offline   Reply With Quote
Old 10-21-2021, 09:42 AM   #7
OK,, AM update. Found Pplex panel beside bed. THANK YOU. I took panel out and unplugged phone cable, no go. I did see little battery, looks tough to remove without breaking something.. I called Dan and left message. Main Pplex panel has power and I can scroll thru. I have to lay on floor under bed to see it. Slides in. THANKS for all the replies they have helped me a bunch. I feel like I am making head way. Hoping Dan calls me back when I can slide under there. Daughter getting married Sat.
2019 JLR toad
2019 Berk 45B
Old 10-21-2021, 09:59 AM   #8
Diesel Rep West Coast
Are you able to connect to the multiplex APP through your from? the Blue tooth app should give you the ability to at least run the slide outs out to give you the ability to get to the panel underneath the bed. Also call Danny At precision his number is 1-630-515-9100 ext 704. He can help trouble shoot.
Eric B FR Diesel is offline   Reply With Quote
Old 10-21-2021, 01:48 PM   #9
Back to normal. Dan called and had me remove the small battery. That worked. He said with battery dead it won't power up , but with no battery it will work fine but won't remember anything you program in if you shut main batteries off. BT437 got it right.
I never had a chance to try it untill Dan called.
Thanks to everyone who gave an answer. The wedding is on!
2019 JLR toad
2019 Berk 45B
Old 10-21-2021, 02:13 PM   #10
Where exactly is that battery located? Is it
behind the main unit under the bed?
Glad you got it up and running!
2019 Berkshire 34QS
Old 10-22-2021, 06:33 AM   #11
The battery is on the back of the LCD panel on the wall. There is a plastic cover on each corner - remove those to expose the screws to remove the panel.
Ty & Deb Montag
2020 Berkshire XLT 45A
2021 Jeep Gladiator
anaviator is online now   Reply With Quote
Old 10-22-2021, 07:40 AM   #12
Thanks. I had to replace that screen last year but didn't notice the battery until today. I looked back at pictures I took last year and there was the CR1025 battery. I wonder does this battery need replacing as part of routine maintenance?
2019 Berkshire 34QS
Old 10-22-2021, 01:13 PM   #13
its the first thing I would check if the screen is not working. Also if you download the App Precision Plex, the bluetooth should still pair to your phone if the screen goes out as the blue tooth module is not built into the screen itself. This will allow you to be able to run the slide outs out and give your self more room when needing to access the panel or brains of the system.
