06-27-2015, 07:43 PM
Need a little help with water smell
In early spring I ran bleach through the entire plumbing of our 2011 390BH including the hot water heater. We have taken 2 short weekend trips and everything was fine with the water. Now we are up in Mount Rushmore for a week and turned on the hot water and it smells like rotten eggs. The cold water smells fresh it is just the hot water. How do I fix this there is no way the wife is going to use the public showers.
Also could someone tell me what size socket is used to remove the drain plug of the water heater.
I will have to check the responses in the morning since the campground we are in only has WIFI at the office and not the whole campground
Thanks for your help in advance
06-27-2015, 08:01 PM
The rotten egg smell is sulfur the park where you filled up probably has some sulfur in their water. The longer it sits the more you will notice it and when its heated it will be more noticeable. Drain your tanks including the HW, refill the system with water and chlorine run some thorough the system including HW. Let it sit overnight then light HW next day. It should go away after this but if not it will in time.
Think about things before you do them make life easier not harder.
06-27-2015, 08:06 PM
If its the same Suburban tank I have, the drain plug/anode rod is 1and 1/16
2015 Shamrock 23IKSS, Oyster shell
2019 Chev Silverado LT Z71 Ext. Cab, 4x4, 5.3L V/8
Reese Straight Line WDH, 2000W Honda Gen.
2 Old Town kayaks & 2 Boston Terriers - Zoey/Gonzo
Lar & Ruth
06-27-2015, 08:09 PM
You may want to drain the low point drains again. I have had an issue with our park model and the washer connection, antifreeze mixing with chlorinated park water causes similar smell.
B and B
06-28-2015, 05:59 AM
90% of the time it is bacteria in the water heater and it puts out a bad sulfur smell. It is not harmful. Google it and you will find what to do. I had the same problem and put a mix of bleach and water (can't remember the ratio) and let it stand for 24 hours. It will get rid of it. RV stores also have a product you can use. Flush all hot water lines after.
06-28-2015, 06:04 AM
The manual is clear on "odor"; sanitize your system (not just the water tank).
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
06-28-2015, 06:53 AM
How long did the water sit in your system since the short trips in spring? If I won't be in the camper for a couple weeks, I drain everything so the water does not ferment and get nasty smelling.
crunchman
2015 F-250 FX4
06-28-2015, 07:16 AM
i use Taste Pure from walmart in the fresh water tank , maybe drain the HW tank before he mix gets there
06-28-2015, 07:23 AM
Georgia Rally Coordinator
After returning from every trip I drain the HW tank, and drain all other lines using air. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
06-28-2015, 07:34 AM
In all probability, the water heater anode takes a 1-1/16 socket. First, release any pressure in the heater by pulling the release valve, then screw the anode out. You may need an extension on hour wrench. After you drain the heater, put a little teflon tape on the anode threads to help seal it when you screw the anode back in. DON"T reef on it; just snug it up! Good luck.
Kent
2019 Flagstaff E-Pro 19FBS
2017 Honda Pilot
06-28-2015, 07:44 AM
More info on "water smell"
We just moved to a sticks and bricks on a well, rotten egg smell (drained the hot water added bleach, 3 weeks later smell was back).
This has worked for us. (replaced the Anode rod)
Solving rotten-egg odor in water heaters
Bought it here, cut to correct length.
Robot Check link to Amazon
2012 Georgetown 360
SHE wanted "a new motorhome"
06-28-2015, 07:55 AM
If you have a magnesium anode, change it out with an aluminum anode. The magnesium anode can cause the rotten egg smell you are experiencing. The smell is actually caused be bacteria reacting to the, magnesium anode, iron in the tank and water you hooked up to.
The smell will come back if all you do is sanitize your system.
06-28-2015, 08:06 AM
A p.s. To my last post. You can identify the type of anode by looking at the end of the external end. Magnesium rods have a button in the middle. Aluminum rods are flat and may the letters AL stamped into the end.
06-28-2015, 08:19 AM
Magnesium without "pimple"
SP11309C - Rheem SP11309C - .7" x 44.375" Magnesium Anode Rod
Magnesium with"pimple"
Rheem SP11524Z Water Heater .840" x 58-3/16" Magnesium Anode Rod
Not sure what that means in this context...
I never had one with a pimple before...
06-28-2015, 08:21 AM
This I was not aware of. I do not use magnesium and have never had a hot water odor problem. I had no idea they were related.
Thanks!
06-28-2015, 08:23 AM
The first year we used our used hybrid we had this smell and could not figure it out. Thought it was sulfur in the water but got it every where we went.. I sanitized the water heater only. Never had it again for the 5 years we owned it.
If you are relating to the fresh water tank when you say entire system I would agree with you if you use your fresh water tank. I never do.
06-28-2015, 09:02 AM
Are you filtering the incoming water?
Ohio
2016 Cedar Creek 36ckts
2015 Ford F-350
4WD SRW Diesel
06-28-2015, 09:28 AM
Bacteria travels, but in this case the specific bacteria loves hot water and may also be in your hot water pipes. Personally, if I am taking the time to sanitize I do everything.
06-28-2015, 09:37 AM
I did run the sanitized water through lines before letting it sit for 24 hours.
A thousand times yes.
Low points, WH tank, fresh tank, outside and inside shower, bathroom and kitchen faucet, if water moves thru it clean it.
