Originally Posted by RetiredAF1955-1981
Run a line from your winterizing selector to the bladder and use it as you water holding tank. It would be same setup as winterizing your trailer.
This is true, if you can leave the external water bladder or tank in position, it can serve as the pump source without going through the step of pumping the water into the FW tank.
