Old 08-20-2020, 09:47 AM   #21
DouglasReid's Avatar
For those of you having wear issues just purchase a short length of rubber hose that will slip over the valve stem,
Slip it on as far as it will go, mark it so you can cut it off so the threads are showing and put the cap back on.
The rubber hose would act to prevent wear on the valve stem, and nobody would notice that piece of rubber but you.........easy fix for those Freightliner inserts that slip off and do nothing then.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 08-20-2020, 12:07 PM   #22
Same problem here on a 2020 Berk. I discovered that the extensions were worn through when attempting to install a TPMS. Both rubber isolators had become detached from the wheel.
I ended up removing the extensions and screwing the TPMS directly to the inside tire. It's possible to fill it up the inside tire without the extension with a 6" air nozzle, but not ideal.
Pitdad Brian is offline   Reply With Quote
Old 08-21-2020, 02:17 PM   #23
RKNOLA's Avatar
Originally Posted by btritschler1437 View Post
Karen please give us more details on what you bought for your tire extenders. I'm having the same problem.
Rick bought it from Amazon. Had to do some slight modification on the mounts. Instead of mounting to the lugs he mounted it to the center hub cover.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Karen and Rick
2020 Forester 2251SLE
Previous: 2018 Berkshire XL 40C
2011 Honda CR-V toad
RKNOLA is offline   Reply With Quote
Old 08-21-2020, 04:06 PM   #24
CZNEDY's Avatar
I got mine when I brought our rig into freightliner for our annual service. Just tell them you need them before your appointment so they can order them.
2020 S.O.B.
2016 Jeep Wrangler 75th and a
Cooler full of good ideas
Full Time in the Summer, soon
Part Time in the Winter
Days Camped, Not Enough
CZNEDY is offline   Reply With Quote
