04-20-2016, 08:38 AM
#41
Wayne
Did you put them in or did the rig come with them? I'm waiting until FR is finished with the warranty punch list work before I start doing to much in the way of upgrades. Although I had my son and his friend install the battery slide tray last weekend. For $100.+ dollars it should be a standard item on all the Berkshires.
Paul
2015 XL 40QL-60
2015 Jeep Wrangler Unltd. Sahara
04-20-2016, 09:42 AM
#42
Originally Posted by Paulie Boy
Wayne
Paul
2015 XL 40QL-60
Paul they were standard. I knew the sink had one cause the DW dropped her diamond earring down the drain last year so I went after it. When I was exploring the heat duct under the shower last week low and behold the shower has one as well. Those are the only drains that I see with them on but now reason they all can't IMO.
Wayne
Wayne
04-20-2016, 09:55 AM
#43
Wayne
Wayne, did the ring get trapped in the valve, or did it get past?
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
04-20-2016, 10:17 AM
#44
Paul it never went past the valve but would run any water after she cried out OMG.
Wayne
Wayne
04-20-2016, 11:26 AM
#45
Wayne
They are a good idea but with minor problems. They take about the same cubic space as a trap, just a different profile. They on occasion get trapped open and allow gray tank gas to leak back. I use 3oz of straight bleach every three months or so to clear the fouling. Let sit 30 minutes and flush out. Traps are much more costly than the generic u-tubes are. We also have two Hepflo's
04-20-2016, 06:57 PM
#46
Vince another positive for those of us living and staying in the frozen north is they don't require pouring antifreeze down the drain since there is no water to freeze.
Wayne
Wayne
04-20-2016, 08:00 PM
#47
Berkshire club
Just fry yourself up a pan of Bacon, every body loves bacon and soon you'll forget you had a smell then the coach will smell like crispy bacon ... better than the other smell
it take a good while for the new to wear out.
2014 360QL-60 Mystic Garnet
04-20-2016, 11:31 PM
#48
Originally Posted by VinceU
The Industrial Hygentist are required in attendance whenever hazardous conditions exist or may exist. They detect and nullify dangerous situation including chemicals, gas, dust and industrial operations. NFPA and OSHA regulate and require their their attendance. They come under safety company services. Of course we utilize them multiple times often through Contractors, or direct. Google the term, there is a bunch of info about them......
Vince, Thanks for the tip.
2016 Charleston BH
2017 Jeep Wrangler Rubicon - purple - toad
04-21-2016, 04:34 AM
#49
just a thought- I do commercial heating and a/c. And a requirement in some new buildings is to bring the building to 110f for 8 hours while providing about 20% fresh air to ventilate the space. This will cause the VOC's to off gas at a much faster rate and the ventilation air gets the chemical out of the rig. If it is an odor from inside, from a chemical that should do it.
04-22-2016, 11:45 AM
#50
That's a very interesting idea that makes a lot of sense. Has anyone tried it?
2016 Charleston BH
