07-16-2017, 08:33 AM
Passenger side rattle
Have a rattle in wall next to front passenger seat in 38A. It's intermittent not related to road bumps or any factors that I can duplicate. It's loud and rapid then goes away. Any suggestions?
07-16-2017, 10:10 AM
Most likely the mud flap or the inner fender skirt. Those are two of the common ones.
07-16-2017, 10:18 AM
I had loose front shocks.
07-16-2017, 11:59 AM
I had carpet on the steps that were held on with springs and they would flap in the wind. Took forever to find the noise. Glued the carpet down. Good luck.
Bill
2015 Charleston 430RB
07-16-2017, 12:14 PM
I had the same problem. The mud flap was flexing and banging in the wind. A bungie and piece of foam from a pool noodle fixed it.
2014 390RB-60 "The Shire"
07-16-2017, 01:31 PM
The inside portion of the mud flap has nothing bracing it. Drill a hole thru bracket and attach to front side of step. Noise will disappear
07-16-2017, 10:17 PM
Ok I'll check both
07-16-2017, 10:18 PM
Thank you
07-16-2017, 10:19 PM
No carpet on my steps. Thanks for the suggestion
07-16-2017, 10:20 PM
That sounds like a reasonable explanation. I'll check it out. Thank you
07-16-2017, 10:23 PM
I'll be checking out this mud flap. That sounds like a good fix. Thank you
08-09-2017, 11:20 AM
I had a rattle on my 2014 390bh and found it was the small screw cover on the front of the door awning. It is a small 1/2 dollar size metal cap that would ratlle while driving. I taped it up with black electrical tape and have not had a rattle since.
08-09-2017, 11:58 PM
Thanks to everyone. As a result of all the suggestions I finally found the problem. The square steel tube frame that holds the wheel well liner (in front of the passenger front tire) was vibrating against the side of the retractable step sheet metal frame. The two touch and vibrate/rattle as they are not fastened together. I inserted a 3/16 x 1-1/2 square medium-hard rubber bumper and that seems to have solved the problem. I hesitate to drill through the side wall of the steps but that's another option if needed. It took me a while to find the spot because I kept thinking it was the mudflap & frame behind the tire.
08-10-2017, 06:41 PM
it sounds like the front arm of the awning,see if you can push the inner arm in,what you hear is air vibrating the metal of the two arms
08-12-2017, 09:14 AM
Now if we can get the driver's window to stop creaking and rattling we will be on to something!
Karen and Rick
2020 Forester 2251SLE
Previous: 2018 Berkshire XL 40C
2011 Honda CR-V toad
08-19-2017, 08:44 AM
Old Member
RKNOLA, hope your stay at Reyford Crossing went well, hope you had an opportunity to sample Corkscrew BBQ at Old Town Spring. We're in Williamsburg VA with our 2018 40B Berk and that dang driver's window has not slowed down on the creaking/rattling one bit since we started out in late July. PM me and let me know about your WH upgrade and trip to TX. We're headed to Elkhart for this and other issues. Will let you know what FR thinks about it. BTW, Freightliner Bootcamp I was a hoot! Good info on a lot of chassis issues.
Drivin, Miss Daisey & the boss, Toppi
2018 Berkshire XL40B-380, SFE=244
08-22-2017, 10:08 AM
My drivers side window was 'worked on' by Herr techs at the rally and the creaking and rattling is just as bad as before the work was done. In addition to my drivers side window, the entrance door manufacturer had techs at the rally to look at my door which was leaking when it rained and also made (and still makes) a terrible creaking noise which is driving us crazy. Not only is it creaking, it now rattles when we hit bumps in the road. I guess the new locking mechanism did not fix the issue. So, I went from only creaking to creaking and rattling. This has been going on for almost 3 years now. Supposedly the door was adjusted at the last 2 rallies but noting that was done seems to help.
I'd be interested to hear if anyone else has the creaking/rattling window and or door issue.
Tom and Margaret
2014 Berkshire 390bh-60
08-22-2017, 01:30 PM
Tom
Since those same guys worked on my door at the rally it is worse than before. Now it doesn't stay open in the wind and the lack is so tight you break your fingers trying to open it. Still have the air leaks. Feel your pain brother
08-22-2017, 02:00 PM
Marty,
At least you are still under warranty and should be able to get it fixed at a dealer that handles FR products. I will have to live with it until next rally or pay to have the 'repairs that were done' fixed myself. I find it hard to believe that your new XLT is having so many similar problems as my '14. I would have thought that in the 4 model years between our coaches that FR would have made some manufacturing/supplier changes to eliminate these annoying issues.
ps- how was the eclipse??
Tom and Margaret
