Old 10-02-2020, 09:46 AM   #1
Patio Awning chatter
Anyone else seen this? The patio awning chatters when retracting. the noise is coming from the contact between awning material and the crossbar at the arm joint. Is there some way of lubricating the crossbar. the awning hasn't been used that much as the Beast (2020 XL 40E) only has 3500 miles due to Covid and other medical issues.
Trappfarmer is offline   Reply With Quote
Old 10-02-2020, 05:56 PM   #2
Mmnsc's Avatar
I have 2 awnings on my coach and both make the chattering noise on retraction. 2 years ago I had Carefree the maker of the awnings check it out and their technician adjusted the awnings but they still chatter. The tech said that the chatter was considered normal.
Mmnsc is offline   Reply With Quote
Old 10-02-2020, 06:56 PM   #3
Nightshifter's Avatar
Are you sure it’s not coming from the gas shocks. Mine made the same noise. I cleaned the shock tubes. Then I sprayed a clean rag with silicone spray lube and wiped the shocks with the rag. The problem went away.
2019 Berkshire XLT 45A
2019 Jeep Rubicon JL
Sold prior to buying the Berkshire
2016 Ford F350 Platnium
2017 Heartland Landmark 365
1989 Winnebago Super Chief
Nightshifter is offline   Reply With Quote
Old 10-02-2020, 07:48 PM   #4
Just as confused as you
Scrapper's Avatar
X2. My A&E Dometic awnings gas shocks chatter also. Just wipe the rods off with WD40 on a rag and they stop chattering until the dust and grime builds back up. Depending on how often and how long the awnings are deployed you may have to do it once a month.
Richard & Jill
Camping since 1989
I deserve hazard pay when camping with my relatives.
Old 10-02-2020, 07:58 PM   #5
You got it I just figured the silicone spray wouldn’t attract dirt.
Funny the tech couldn’t figure that out.
Old 10-03-2020, 06:29 AM   #6
Struts. Huh.
So they’re not going to snap in half? And the fabric isn’t going to tear?
Old 10-04-2020, 10:11 AM   #7
Thanks for the answers
I used an Amsoil lubricant spray on the gas struts. This is what I wiped off on the paper towel. There was a ridge at the end of the shaft travel that I removed with a little effort.
The crossbar at the center hinge of the control arms was tacky on top where it meets the awning material. I used a silicone spray and paper towels to wipe off the excess and the tackiness.
Very smooth at this point.
awning
