Thanks shepardmike for recalling my post.
I'd better help wdweldon find it, because it is not in a thread that I started. That thread was about sagging steps on another coach. I sort of hijacked that thread for a sagging step problem that I had, which was different, but for which the earlier thread provided some valuable advice and photos of the front steps. Then, to finish the hijacking process, I hijacked my own post with a discussion of the loose fender flap, because it is in the same area and all the photos I had showed how to work on that.
So, here is where you want to go to see my fix to the loose fender flap. If it flaps too much, it will fall under the RF wheel while you are driving. That will make it easy to find the problem – just follow the trail of damaged bodywork and frame back to the source.
https://www.forestriverforums.com/fo...ml#post2177789
The link is to my stair fix and it has lots of photos. The next post is my fix for the fender flap.
I really dislike it when people hijack threads. Now I have to go to bed and loathe myself!
–Gordon
