Old 07-31-2020, 08:32 PM   #1
rear view camera images are dark
I have a 2020 Berkshire 39A with a question concerning the rear view camera. It seems like the images are not very clear and are very dark on the monitor, even in daylight. Has anyone experienced similar problems? I may have to change out the camera, but I am not sure what to replace it with. My last 2 motor homes did not have this issue, I am not sure how to best correct the problem. Any suggestions will be appreciated.
taquarium is offline   Reply With Quote
Old 07-31-2020, 09:13 PM   #2
CincyGus's Avatar
Have you checked the settings for the monitor? usually there are brightness and contrast settings on the monitors settings to adjust picture quality.
2020 Chevrolet 2500 LTZ, 2019 Forest River Wolfpack 23Pack15, 2014 EZGO Golf Cart.
CincyGus is offline   Reply With Quote
Old 08-01-2020, 06:16 AM   #3
Hi Gus,
The dealer tried to make some adjustments with little improvement. I will pull out the manual today and make another attempt to adjust settings. Thanks,
Terry
Old 08-01-2020, 07:01 AM   #4
Kanadian Kamper
kenandterry's Avatar
Follow up questions...
Youíre mentioning how dark your images are from the rear camera.
Do you have side mounted cameras? How do they look?
Ken and Terry
2018 Sunseeker 2430S with Trekker cap
and only rarely pushed by our 2017 GMC Terrain toad (4 wheels down)
Former Georgetown 330TS owner for 10 years with more mods than I can count.
kenandterry is offline   Reply With Quote
Old 08-01-2020, 07:39 AM   #5
The side camera images are just fine, clear and bright. I did try to make some adjustments on the monitor without success. I think I will try to call Mobile Vision on Monday. The rear camera is a Mobile Vision Model C122.
Old 08-01-2020, 08:18 AM   #6
Kanadian Kamper
Ok then.
Your problem is with the rear camera itself, not the monitor.
Are you still in the warranty period for a replacement?
Ken and Terry
Old 08-01-2020, 08:56 AM   #7
Yes, still under warranty. However the selling dealer is 16 hours away. I will try to contact them, but the camera is working, just not well. I am wondering if this is the best this camera will do, it may not be defective, just a lesser quality than what I had in my previous motor home.
Terry
Old 08-01-2020, 09:36 AM   #8
Mmnsc's Avatar
There is an upgrade camera available from the company that makes the monitor. I canít remember the model number but when I talked to the rep they even gave me credit for the original camera. The upgraded camera made a world of difference in image quality. It was a simple plug in replacement when you pull the old camera off and the cable has a plug. Sorry I donít have any of the model numbers or contact info.
Mmnsc is offline   Reply With Quote
Old 08-01-2020, 09:46 AM   #9
Thanks for the comment/suggestion on upgrade. I will make contact with them next week.
Terry
Old 08-01-2020, 12:44 PM   #10
Maingler's Avatar
https://magnadyne.com/rv/camera-syst...lphaasc&page=2
MAGNADYNE CAMERA rearview
Maingler is offline   Reply With Quote
Old 08-02-2020, 02:04 PM   #11
rfifer
One thing to watch for that I just discovered on my back up camera is an "auto dim" feature. Be sure that it is turned off and then re-adjust the brightness and contrast. Don't know if your camera/monitor setup is similar, but thought I would offer an idea that worked for me. My image was also very dark until turning off the auto dim feature.
Bob and Jan
Miami
Grey Wolf 26 DBH
TV F-150
rfifer is offline   Reply With Quote
Old 08-03-2020, 06:12 AM   #12
We have a 2020 45A and the image from the rear camera is excellent. I would definitely contact the manufacturer (or reach out to Forest River) and have them send you a replacement.
Ty & Deb Montag
2020 Berkshire XLT 45A
2014 Honda CR-V toad
anaviator is offline   Reply With Quote
Old 08-03-2020, 09:52 AM   #13
Diesel Rep West Coast
Can you post a picture? Also what are the setting on the radio?
Eric B FR Diesel is offline   Reply With Quote
Old 08-03-2020, 02:57 PM   #14
To change the Brightness of the screen try the following;
Press home> settings> device> Brightness. Once you set it, hit ok to confirm and lock it in.
Old 08-03-2020, 07:54 PM   #15
I have attached 2 pictures, one from the side camera and one from the rear camera. You should be able to see the difference.
Terry
ID:	235572   Click image for larger version
Old 08-03-2020, 10:49 PM   #16
Mmnsc's Avatar
That is why I switched to the C128 camera upon recommendation from the manufacturer. The. C122 camera is junk. The image quality is so much better with the C128 camera. I played with every setting on the monitor (brightness, contrast ) to no avail with the original C122 camera and in frustration contacted the company and paid the up charge to get the upgraded camera
Old 08-04-2020, 08:03 AM   #17
Ok, Thanks for the upgrade suggestion. Did you deal direct with Magnadyne for the upgrade camera? Did you do the install your self?
Old 08-04-2020, 10:37 AM   #18
Mmnsc's Avatar
I purchased the new camera directly from Magnadyne. Complained about the image quality and the offered a substantial discount on the C128 camera.
Did the install myself. Real easy, a few screw removal, pull the cable out from the body of the motorhome and disconnect the camera from the plug and the just plug in the new camera. You might have to adjust the angle to get your desired view
Old 08-07-2020, 07:07 PM   #19
RKNOLA's Avatar
RV Cams: Backup Camera Systems (All)
Rick and Karen
2018 Berkshire XL 40C
2011 Honda CR-V toad FB
RKNOLA is offline   Reply With Quote
Old 08-08-2020, 12:41 PM   #20
There is merit in sticking with the Magnadyne upgrade rather than switching brands.
I found that Magnadyne uses non-standard pin configurations for the side cameras, and they may do the same for the rear. Thus, another brand of rear camera may require re-wiring the pins.
ĖGordon
Gordon Sick, Calgary
2015 Berkshire 34QS
The Manual I wrote for our 34QS:
https://www.forestriverforums.com/fo...qs-191578.html
Toad: 2019 Ford Ranger XLT 4x4; Formerly: 2005 Acura EL (aka Honda Civic)
gordonsick is offline   Reply With Quote
camera
