Old 11-25-2018, 09:55 PM   #1
ernest917's Avatar
Replaced Magnum Inverter Remote Control
I finally replaced my factory installed inverter remote control (idiot light version) with the new ME-RC remote control....
Talk about a major difference!!!! Love the information I’m now able to obtain....
Old Remote
New Remote
ernest917 is offline   Reply With Quote
Old 11-27-2018, 05:58 AM   #2
CZNEDY's Avatar
Hahahahaha, that old remote looks like you had to really pound on it to get it to work. Nice upgrade.
2020 S.O.B.
2016 Jeep Wrangler 75th and a
Cooler full of good ideas
Full Time in the Summer, soon
Part Time in the Winter
Days Camped, Not Enough
CZNEDY is offline   Reply With Quote
Old 11-27-2018, 08:00 AM   #3
yes, our coach came with the ME-RC and I couldn't imagine having only the simplified 'other' version... as the ME-RC gives you so much more information, control, and troubleshooting data - including the AGS setup, Fault codes, and even internal inverter Temperatures, as well as the normal DC Volts for battery levels.
The Turners...
formerFR is offline   Reply With Quote
Old 11-27-2018, 11:29 AM   #4
ernest917's Avatar
I got mine from Inverter Supply - $134.00.....
Old 11-27-2018, 11:30 AM   #5
ernest917's Avatar
CZNEDY.....
Just many years of use....
Old 11-27-2018, 04:30 PM   #6
fredhardy's Avatar
Earnest - I read the operations manual this past summer and was blown away with the settings and information it presents. I changed some of settings immediately.
Regards,
Fred
fredhardy is offline   Reply With Quote
Old 11-27-2018, 05:49 PM   #7
ernest917's Avatar
Fred.....
I did also..... I find it interesting to be able to see how many amps I'm using at any given time..... I most likely will be adding the AGS feature to my system this Spring because I see it
Old 11-27-2018, 05:50 PM   #8
ernest917's Avatar
as something I can use.....
Old 11-27-2018, 10:11 PM   #9
Eagle5's Avatar
yeeeeeaaaa buddy! you're in business now.
2019 34QS with no ladder!
Eagle5 is offline   Reply With Quote
Old 11-28-2018, 12:56 AM   #10
Dragonship Captain
Oscarvan's Avatar
Originally Posted by ernest917 View Post
Fred.....
Not so fast.... The amps you are seeing are the amps the INVERTER is using.... Interior/exterior lighting, furnace blower etc are in addition to that.
In order to see ALL the amps you are using you need to add a BMK... Battery monitor kit, which will ADD this data to the remote.... Good news is that it is (almost) plug and play.
Read about it (and a lot of other info on your 12V system) here: https://dragonship.blog/battery-monitoring-kit/
2020 RAM 3500 DRW Long Horn. In the hunt for a Palomino TC, formerly a 2017 Berkshire 38A: https://dragonship.blog/
Oscarvan is offline   Reply With Quote
Old 12-19-2018, 10:33 AM   #11
jmgllt's Avatar
Was is a direct replacement?
jmgllt is offline   Reply With Quote
Old 12-19-2018, 11:21 AM   #12
ernest917's Avatar
Yep...... unplug the old one, enlarge the wall cut-out, plug in the new one and its done... (except for adjusting a few settings)
Old 12-19-2018, 12:27 PM   #13
planopat's Avatar
Oscar, That's something I've thought about doing. Our rigs are practically identical. I'm not an electrician but can follow instructions so how much time to do this install?
planopat is offline   Reply With Quote
Old 12-19-2018, 12:30 PM   #14
planopat's Avatar
….that is to add the BMK.
Old 12-23-2018, 04:28 AM   #15
Dragonship Captain
Oscarvan's Avatar
If you have it all ready to go (including tools) a few hours. I took my time and spent about 4, including playing around with it after it was hooked up.
Old 12-23-2018, 12:34 PM   #16
2011 Berkshire 390BH
Installed Yourself?
I too have have the old model, that really tells me nothing. Ended up having to replace inverter last year -- maybe age related, since my coach is 2011, or a surge (something "fried" a hookup) -- and also got a Hughes power conditioner/surge protector. I like the idea of having some real information from he newer model.
Did you did the install yourself? If so, was it difficult?
daverule is offline   Reply With Quote
Old 12-23-2018, 03:02 PM   #17
ernest917's Avatar
Simple install..... just need to enlarge hole in wall then simply plug it in and it automatically downloads info...
You’ll need to tweak a couple of the setting but no big deal..
inverter, remote
