11-02-2015, 03:42 PM
#41
Originally Posted by Paulie Boy
I have K307
Paul
Me too.
Rich
11-02-2015, 03:43 PM
#42
Paul,
Wise decision. I wouldn't want to mess with it either.
Tom and Margaret
2014 Berkshire 390bh-60
11-02-2015, 03:51 PM
#43
Rich they'll pay for the part, you pay for the service.
Paul
11-02-2015, 03:56 PM
#44
Mine is a K307 also.
Joe & Lori
2014 Berkshire 390 RB-40
11-02-2015, 04:03 PM
#45
K308 on mine.
Dan
2014 Berkshire 390RB-60
11-02-2015, 04:40 PM
#46
Oh you poor guys with those newfangled fridges. Troubles troubles. Nothing but troubles.
11-02-2015, 04:52 PM
#47
Paul
Hey Paul, I'll see if I have any problems without using the icemaker. If not, I think I'll just let it go.
Rich
11-02-2015, 04:58 PM
#48
Rich,
Don't think it has to do with the ice maker. The Technical Service Pointer that the link was posted for talks about ice build up on the bottom of the freezer and the defrost water does not drain due to a clogged valve. Sounds like the clogged drain valve is the problem.
Tom and Margaret
11-02-2015, 05:10 PM
#49
Also what I get out of it Tom.
Joe & Lori
11-02-2015, 05:16 PM
#50
Originally Posted by dan-nickie
K308 on mine.
You're good to go, anything before K333.
Paul
11-02-2015, 05:17 PM
#51
You're just jealous, how many Dometic units have been in and out of your rig? The way I drink Manhattans I have to have an ice maker😋
Paul
11-02-2015, 05:24 PM
#52
I called Whirlpool, they have an RV department. Who knew? Anyway, they only cover labor for one year now, not two years that was on the original Service Pointer. They still cover the part and they arrange the service call appointment. How cool is that?
Paul
Paul did they give you an explanation on why they are stating only for part now when their Technical Service Pointer clearly says 2 years for parts and labor which should be charged to their Special Project # S38211 ?
Now this is from TSP # W10632338A which supersedes # W10632338.
Do they have a new TSP which supersedes #W10632338A stating only parts ?
Joe & Lori
11-02-2015, 05:45 PM
#53
Originally Posted by tmmar
Rich,
Well then Tom, I guess that I may have to rethink this then. Thanks
Rich
11-02-2015, 05:48 PM
#54
Paul
Well if your going to keep track the number is two and several fixes. It is working great and us old fashion guys even have a functional ice maker.
11-02-2015, 05:49 PM
#55
She said there is a B suffix now.
Paul
11-02-2015, 06:11 PM
#56
Paul
Don't see one. They're going to have to email me a copy of that. How can they just change these whenever? I'm going to insist on parts and labor !
See where that gets me !
Joe & Lori
11-02-2015, 06:24 PM
#57
Bull in a China Shop.
Paul
11-27-2015, 07:56 PM
#58
I had this fix performed today. Whirlpool set up the appointment for me. When I explained the fridge was in an RV, the tech reserved the right to back out. I said okay, let's do it, it's a 2 man job. Here's what we had to do. Bought 2 milk crates and 2 light moving blankets. Removed the fridge drawer front panel (4 screws). Removed the fridge wheels cover. Removed the 3 screws holding the fridge in place. Removed the top right door top hinge cover and hinge, Lifted the door off. Removed lower door hinge and lower right wheel assembly. Pulled the lower wooden cover off from below the fridge and unplugged it. We had to pull the cord and water feed from foam insulation/sealant. Tied a pull string on the power cord so it wouldn't sneak away. Placed 1 moving blanket on the floor and placed the milk crates at the outside edges of the fridge. Pulled the fridge out slowly and slid crates under the side frames. Placed the other blanket over the front of the fridge. When it was about 2/3 out, I pushed the bathroom side of the fridge out more than the front side. This twisted the fridge and allowed it to be carefully slid out to the edge of the back. It's really tight! The tech removed the back cover (6 screws) and installed the new P-trap. Reversed the process and it's done. Total time - Less than a hour. It can't be performed by 1 person. No more water on the floor during auto-defrost cycle. All under warranty of the fridge.
I tipped the tech $20 for sticking it out with me. He really wanted to quit twice. The hardest part was figuring out the process. The fix took less than 1 Minute!
Regards,
Fred
Fred Hardy
Phoenix, AZ
2014 Berkshire 390BH-60
2007 Explorer Sport Trac
11-27-2015, 09:18 PM
#59
And this was in a BH? RB should be a little easier.
Dan
11-28-2015, 12:13 AM
#60
Just curious ... what year did FR start putting residential refrigerators in the 390BH. Our 2012 has a dometic side by side.
What is the advantage of residential other than cost?
