Old 10-24-2020, 06:08 PM   #1
edgewant's Avatar
Reverse/back up lights not working
Anyone had this issue and have any insight.
Iím on the road so am reluctant to do too much.
Checked all the fuses and all are good. Checked for ground on one of the four lights and it checks good. Checked one of the 4 bulbs and itís good.
Didnít test relays but plan to when I return home.
Found the supply wire coming out of the firewall from the TCM but havenít checked it for 12v when in reverse.
Contacted Freightliner and they mentioned checking all the ignition fuses in the box in the compartment below the drivers seat. Every fuse checks ok.
Any thoughts.
edgewant
2013 Berkshire 390RB-60
toad - 2002 Jeep Wrangler Sport
edgewant is offline   Reply With Quote
Old 10-25-2020, 08:41 AM   #2
ceedog's Avatar
In my 2011 Berk there are fuse banks in the electrical bay that aren't listed in the manual.
Some of the circuits for the rear of the RV are fused there.
It ain't easy being me...I've tried.
ceedog is offline   Reply With Quote
Old 10-25-2020, 08:54 AM   #3
Maingler's Avatar
Freightliner only supplied a 10A circuit and it wasn't large enough to feed all the lights.The back up signal from Freightliner feeds a relay in the front elctrical comparrment and a fused circuit from the Berkshire fuse panel feeds the lights.
Maingler is offline   Reply With Quote
Old 10-25-2020, 02:39 PM   #4
edgewant's Avatar
Any idea which Berkshire circuit.
I just tried putting 12v to pin slot 87 on the reverse lamp relay circuit and no lights. Iím beginning to think it may be a splice that has worked loose in the rear cap.
Thereís one big bundle of splices in side the cap. I believe it splices the four tail light circuits into the freightliner wiring.
edgewant
Old 10-25-2020, 04:12 PM   #5
Maingler's Avatar
Ill look at it tomorrow and let you know where to look.
Old 10-26-2020, 09:12 AM   #6
Maingler's Avatar
15A trunk light fuse in Coach Fuse Panel feeds the rear lights and I attached taillight harness. Relay in rear should be located rear passenger side. Blue wire is back up chassis signal to relay.0610-500101.pdf
Old 10-26-2020, 02:00 PM   #7
edgewant's Avatar
15A trunk light fuse in Coach Fuse Panel feeds the rear lights and I attached taillight harness. Relay in rear should be located rear passenger side. Blue wire is back up chassis signal to relay.Attachment 241932
Thanks. Are any of the unmarked relays in the compartment below the drivers seat involved?
edgewant
Old 10-26-2020, 02:35 PM   #8
Maingler's Avatar
This will make more sense. There should be a 15A inline fuse at the batteries REV 14 PUR runs to pos 30 on reverse light relay. Click image for larger version
Old 10-26-2020, 02:45 PM   #9
edgewant's Avatar
Found the relay and it checks good. Itís in the most aft compartment on the passenger side.
Looked in chassis battery compartment and found one 20 amp in line fuse.
Is that the right one?
edgewant
Old 10-26-2020, 02:54 PM   #10
PDM panel in the inverter box, it fixed mine.Click image for larger version
ID:	241949Click image for larger version
feedfold is offline   Reply With Quote
Old 10-26-2020, 03:09 PM   #11
I wouldn't get backup camera also when my backup lights didn't come on.
Old 10-26-2020, 03:34 PM   #12
edgewant's Avatar
Dude.
What year is your motorhome?
Mine looks nothing like that!
edgewant
Old 10-26-2020, 04:58 PM   #13
2016 34qs
Old 10-26-2020, 05:33 PM   #14
edgewant's Avatar
Mine is a 2013 390RB. It has 4 back up lights. Apparently a 10 amp circuit was insufficient, which I get, so FR added a circuit.
Unfortunately itís not something they share unless you have issues with it.
Just wish they would provide a complete set of schematics especially when they circumvent something that Freightliner has provided.
edgewant
Old 10-26-2020, 06:09 PM   #15
Maingler's Avatar
You have an older unit. Is it a purple wire coming off the fuse?
Old 10-26-2020, 06:15 PM   #16
edgewant's Avatar
The 20 amp fuse in the chassis battery compartment has a red and a white wire.
edgewant
Old 10-27-2020, 07:56 AM   #17
edgewant's Avatar
Itís a purple wire feeding pin 30 on the relay.
But I still havenít been able to locate the in-line fuse. Click image for larger version
edgewant
Old 10-27-2020, 08:04 AM   #18
edgewant's Avatar
Is this the fuse for the backup light circuit?
If so where can I get a replacement?
edgewant
Old 10-27-2020, 10:59 AM   #19
Maingler's Avatar
Thats it, is there power on the blu/wht? Look up short stop or mini breaker. NAPA carries them.
Old 10-27-2020, 02:05 PM   #20
edgewant's Avatar
The blue/wht wire does indeed have 12v on it. The fuse circuit tests ok.
I also tried jumping from pin 30 (purple) on relay to the pin87 (orange ). No reverse lamps. So now I wait till I get home in a couple weeks to look for a bad splice.
Thanks for all your help.
edgewant
light
