Old 11-04-2020, 09:49 PM   #1
Right rear taillight in flames
My wife and I was pulling our 2014 390FL out of storage for a short 4 day trip when the right taillight assembly burst into flames. Luckily we had a fully charged fire extinguisher to put the flames out.
Has anyone else experienced this issue?
The inside of the coach is smoke filled and smells like burning plastic.
We have full coverage insurance and a extended warranty policy where should we file a claim?
wdweldon is offline   Reply With Quote
Old 11-04-2020, 10:24 PM   #2
If it were me, I would try extended warranty first,.
If they cover it, or enough of it, you won't have a claim on your insurance.
Mike
TV = 2017 Ram 3500 (aka FRAM)
5er = SOB (2019 Grand Design Reflection 367BHS)
walaby is online now   Reply With Quote
Old 11-05-2020, 05:21 AM   #3
I wonder what caused that? It would have to be some kind of dead short. But why the fuse did not blow before the fire started is beond me.
Please let us know what caused it. (maybe animals?)
2012 390BH
dave-g is offline   Reply With Quote
Old 11-05-2020, 07:58 AM   #4
Animal nest in the tail light assembly maybe?
2020 GMC Denali 4X4 2500HD Duramax
2018 Work & Play 25WAB
sdelam is offline   Reply With Quote
Old 11-05-2020, 11:04 AM   #5
ernest917's Avatar
Son of a gun- now something else to worry about!!!!
ernest917 is offline   Reply With Quote
Old 11-05-2020, 11:06 AM   #6
So what caused it? Corroded terminals and high resistance creating heat?
Direct short with no fuse or circuit breaker?
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
upflying is offline   Reply With Quote
Old 11-05-2020, 01:05 PM   #7
rsdata's Avatar
This would be my bet...
You would not believe the problems I have found created with shorted and corroded lighting on the outside of motorhomes and trailers...
never have I seen one go up in flames, but I suspect it is possible, especially if some insect nest was in there
we could all find corrosion issues on outside lighting if we looked
"Freedom is never more than one generation away from extinction. " - Ronald Reagan
Too much of anything is bad, but too much good whiskey is barely enough.” – Mark Twain
2014 Shamrock 183
Old 11-05-2020, 01:15 PM   #8
SetauketJeff's Avatar
Did you piss anyone off? I could think of many ways to use that light to trigger a fire. Just saying..........
Every stop light is a staging light!
2021 Wolf Pup 16FQ.
2007 Chevy Trailblazer LT 4X4 Tow Package, Locking Rear, 157K Just pulled 16FQ 1,044 miles. Husky Centerline TS32215 WDH Round Bar 400-600Lbs.
CURT 51180 Echo Bluetooth Brake Controller (Love it!)
2004 Ford F-150 STX 4X4 Tow Package, 206K For Pulling TT in the sand
SetauketJeff is online now   Reply With Quote
Old 11-05-2020, 02:04 PM   #9
Lights look to be in great condition, no signs of birds or rodents. The fire started when backing out of my covered storage unit, lights turned on for maybe 3 minutes maximum.
Old 11-05-2020, 03:37 PM   #10
ernest917's Avatar
Sounds like back-up lite set it off.....
Old 11-05-2020, 03:50 PM   #11
D W
D W's Avatar
These lights wouldn't happen to be LED's with built-in resistors, would they?
Just a thought.
2016 Salem 27RKSS
D W is offline   Reply With Quote
Old 11-05-2020, 10:53 PM   #12
Villagerjjm's Avatar
Insects can cause a fire without affecting a breaker. Ants, spiders or beetles can do it.
Villagerjjm is offline   Reply With Quote
Old 11-06-2020, 12:23 AM   #13
Really....is that experience or conjecture?
koko 3052 is offline   Reply With Quote
Old 11-06-2020, 05:58 AM   #14
Firebugs,............. you know arson-ants.
2021 Wolf Pup 16FQ.
Old 11-06-2020, 08:36 PM   #15
Before I start to get into this, I would like to ask any of the readers of the Forest River forums if they own one of those “fly paddle” things. You know, the one that looks like a tennis racquet that is strung with wire mesh instead of nylon twine. I think they use 2 AAA cells. You push a button that activates a LED to let you know it is active.... 2 AAA cells.... that is about 3 volts combined, right? Anybody??
Well, when you activate the contraption and wave it, it will eventually catch an insect. What happens to that insect? A little crackle and a spark? Smoke? Ever catch a stink bug with one and have it smolder?? Ever have a fly catch fire??
Anyways.... that is 3 volts DC....
Now, a question was asked. Here is the first part of the answer:
https://www.mistersparky.com/expert-...eally-can-hap/
Old 11-06-2020, 08:48 PM   #16
rsdata's Avatar
those bug swatter things, take that 3 volts change it to AC from DC then up the voltage to 20-30 thousand volts using the enclosed circuitry in the swatter... hi-voltage but very low current, which is why tiny skeeters snap and pop, and flys smolder
I don't believe 12 VDC will cause any bugs to smolder or catch fire, but I suppose anything is possible given the right conditions...
I am thinking a paper wasp nest and a hi-resistance faulty connection that heated up till the nest caught on fire. Although the OP described a BIG fire and smoking plastic...
2014 Shamrock 183
Old 11-16-2020, 07:32 PM   #17
I'll be interested to hear what caused that.
Bummer
timbob55 is offline   Reply With Quote
Old 11-16-2020, 08:00 PM   #18
I replaced all my incandescent bulbs with LED. I found that many of the fixtures were partially melted from the heat given off by the incandescent bulb. That might be what caused the fire. I suspect your extended warranty is the best place to start.
wjijr1951 is offline   Reply With Quote
Old 11-16-2020, 09:01 PM   #19
Contrary to popular belief, LED's put out quite a bit of heat, not so much from the LED itself but from the drivers. Thats why most aftermarket LED headlight replacements have cooling fins or fans on them. If the tail lights are LED, and some bug nest or other flammable components got trapped inside the housing, the drivers could generate enough heat in 3 minutes to ignite it without tripping a breaker or blowing a fuse. Only way we will ever find out is after the light housing is inspected. I'm sure we would all like to know. Incandescent can do the same, but take longer than 3 minutes in most cases, the flammable would have to be right on the bulb itself.
I just replaced 6 of my shop florescent fixtures with LED tubes, which required removing the ballasts and all the wires, just wiring one end tombstones to 120v. It reduced 80 watts to 36 watts. I have one set on now for about 20 minutes and if you run your fingers over the top you can feel the heat they give off, and considering they are spaced about 3/8" or more apart, the heat is quite apparent, more so when packed tighter inside a tail light. Of course this is assuming they are LED.
Bhrava is offline   Reply With Quote
Old 11-16-2020, 09:47 PM   #20
I’m going to call BS to at least part of your theory. I have replaced incandescent headlights,
marker lights & tail lights with LED and none that I have used have had any “drivers”. I have read about “drivers” on headlights, but no experience there. None of my LED’s have ever gotten warm. Fact is, if you are in snow country to NOT put LED’s into tail lights as they become encapsulated in snow that does’t melt off making them much harder to see than regular incandescent lights.
light
