08-18-2018, 04:14 PM
Satellite and Matrix
So I am finally trying out my direct TV. Have the box plugged into the Satellite connection above the fireplace. Have the box plugged into the matrix (B) with the HDMI plug. Dish is honed into the satellites. I have the tv tuned to HDMI for the source. No signal to any of the TVs. Not sure what I am doing wrong. Gonna take the satellite plate off and see if it’s connected next. Any help? Thanks
2020 S.O.B.
2016 Jeep Wrangler 75th and a
Cooler full of good ideas
Full Time in the Summer, soon
Part Time in the Winter
Days Camped, Not Enough
08-18-2018, 04:26 PM
so, your 'box'(Dish receiver?)'s output is an HDMI cable into the 'matrix'(Box of many buttons to select the 'source signal' for each tv?), is the output of the matrix box to each TV an HDMI cable?
if you are 'honed in' to the satellites, how would you know that if your TV is not showing it?
08-18-2018, 04:57 PM
On satellites 101 99 and 103. Just no signal to the TV from the box
2020 S.O.B.
08-18-2018, 05:03 PM
All of the cables going to the TVs are CAT5. HDMI from satellite box to the matrix
2020 S.O.B.
08-18-2018, 05:21 PM
is that a Receiver, or just the antenna box?
The Turners...
08-18-2018, 05:38 PM
That’s the antenna box. Camera didn’t read the blue screen
2020 S.O.B.
08-18-2018, 05:44 PM
where is your receiver located? how is it connected? how is the tv connected to it?
08-18-2018, 05:55 PM
On mine, you have to have the correct button on the distribution center selected. Four buttons each with four positions. The one at the end of each series pushes to make the selection. Yours being newer probably has something that performs the same task. I’m sure that’s not the right name for it, but it has a series of selectable button that route the signal from the receiver, dvd,or whatever to the various tv’s. On mine, i also wait and let the antenna find the signal-then I turn on the sat. Receiver and selector button. Usually takes a few seconds then I don’t have to go thru the refresh routine with directv.
2016 Berkshire XL 40A towing 2020 Jeep Wrangler unlimited.
Prior to this Jayco fifth wheel: 24' Eagle, 30'Designer, and 40' Jayco pinnacle.
08-18-2018, 05:57 PM
That’s what I was thinking. Each one of four has four different selections.
2020 S.O.B.
08-18-2018, 05:58 PM
Just not sure if it’s automatic or you have to manually select
2020 S.O.B.
08-18-2018, 06:28 PM
Again, they’re probably a bit different, but mine are manual so I can play different inputs on different tv’s if I want. As long as you have the receiver on, plugged into the antenna and also into that distribution center it’s got to be lurking in there somewhere it seems like.
08-18-2018, 07:36 PM
I’ll keep playing with it and see what I can figure out. Thanks
2020 S.O.B.
08-19-2018, 07:33 AM
The receiver is connected to the satellite dish connection in the cabinet above the fireplace. Then I have an HDMI cable going from the receiver to the matrix box.
2020 S.O.B.
08-19-2018, 08:58 AM
I figured it out this morning. I thought the input and output selections were automatic. Changed the input source on the TV to HDMI and manually selected input B on the matrix (that’s where the receiver is connected) and it works.
2020 S.O.B.
08-20-2018, 07:50 PM
Originally Posted by CZNEDY
I figured it out this morning. I thought the input and output selections were automatic. Changed the input source on the TV to HDMI and manually selected input B on the matrix (that’s where the receiver is connected) and it works. Attachment 183700
It took me a while to figure it out too, since there is NO book or Op Manual and the Indoc guy at Lazy Days where I bought it had no idea how it worked. My one question is can I watch local channels on TV #2 while I watch Directv on TV’s 1 & 4? The local antenna signal amp seems to interfere with the Directv signal.
08-20-2018, 07:54 PM
Yes you can. You just have to manually select them and tune the individual TV to either cable, antenna, dvd or state lite. If you want satellite you have to select HDMI on the tv source.
2020 S.O.B.
