Old 10-01-2020, 03:01 PM   #1
Slides
I opened the 2 bedroom slides but when I tried to open the 2 kitchen and dining room slides they wouldn't work, and when I tried to close the bedrooms they quit working, tried to find breakers can't locate i have a 2014 Berkshire 39rb
wac1949 is offline   Reply With Quote
Old 10-01-2020, 05:27 PM   #2
Maingler's Avatar
There is a 125A breaker in the battery compt that feeds the hydraulic pump. Sounds like you have a 12v issue. Check the 125A breaker and see what your voltage is.
Maingler is offline   Reply With Quote
Old 10-02-2020, 01:52 PM   #3
Got power to the pump everything works but the slides1
Old 10-02-2020, 03:50 PM   #4
Maingler's Avatar
Did you try and run it from the mplex panel under the bed?
Old 10-02-2020, 04:44 PM   #5
Not sure what you mean , i have been on the phone with fr tech 3 times trying to figure out the problem still can't get them to work they didn't mention checking under the bed
Old 10-02-2020, 05:55 PM   #6
Maingler's Avatar
Ok i would like to get you in contact with precision circuits. They can help diagnose.
Old 10-05-2020, 10:43 AM   #7
Maingler's Avatar
Nevermind, i see you have an older unit. Spoke to Mike Winterowd and he said he was working with you.
slide
