Originally Posted by Ole_blue
Fresh water pump isn't going run unless the switch is on. Water or not it needs to be turned on. Not automatic or it would burn the pump up if the water tank was empty.
As I have said before, the pump does *not* turn on using either switch, inside or out and there is water in it. Shows 1/3 full.
Horizontal means just as the previous post describes, flat or in the same direction as the hose. I am hoping it is just electrical and that the dealer will replace it.
I appreciate all the feedback, There is clearly lots of knowledge on this forum. We are getting the rig back Monday afternoon and they are supposed to have fixed the pump issue as well as a couple of other smaller items. Wonder if the ice maker only works off the fresh water tank?
Looking forward to many years with this RV. We had our last one, a Class C from Jayco for 3 years and loved it but really needed a little more room as well as that beautiful diesel engine in the rear. Love how quiet it is compared to having a Ford V10 between us and the fact that I can barely detect when it downshifts, so smooth. Those hills up in Colorado should not be an issue anymore!
