09-16-2019, 07:22 AM
Starting an Electric HW Heater
Have a Suburban S-10 direct vent HW heater in my 2011 Berkshire. To run on electric, do you flip the small toggle switch in the HW heater compartment to on and then turn on the switch in the coach that would normally turn on the HW heater using propane?
09-16-2019, 07:34 AM
No. You only need to turn on the switch on the heater. If you also want to use propane for faster heating you can turn on both, but it isn't necessary. You can use either, or both for faster heating.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
09-16-2019, 07:37 AM
Kanadian Kamper
Can you verify exactly what model you have? The label should be on the inside of the water heater seen from outside.
Typically, if you have both ways to heat the water, the switch inside the compartment is for heating by electricity. The switch inside heats it using propane. They work independently from each other. Some people use both to heat water faster, or sometimes keep the water hot if you’re having back to back showers with others on board.
Ken and Terry
09-16-2019, 07:38 AM
Kanadian Kamper
Woody types faster than me.
Ken and Terry
09-16-2019, 08:13 AM
Don't worry, 40 more people will post the same thing you said.
09-16-2019, 12:26 PM
THIS^^^^
09-16-2019, 02:07 PM
Just as confused as you
I was going to post the same thing but I have this condition that makes it hard to be quick with the replies. It's called lateto thep arty syndrome.
Richard & Jill
09-16-2019, 02:12 PM
Beentheredonethat syndrome.
09-16-2019, 02:30 PM
if you turn on the one outside this one is for electric, Now if you want both on turn on switch inside. I'm a cheep I chose only electric and save propane.
09-17-2019, 09:16 AM
1 down, 39 to go.
