Old 09-15-2020, 12:19 PM   #1
Steel wheel valve rubber supports
Any ideas where I can get the parts for the inside wheel value stem supports and extensions (if needed)?
Name:	value stem supports.jpg
wdweldon is offline   Reply With Quote
Old 09-15-2020, 01:41 PM   #2
Diesel Rep West Coast
I would call a freight liner dealer, they should have them.
Eric B FR Diesel is offline   Reply With Quote
Old 09-15-2020, 08:36 PM   #3
Nightshifter's Avatar
Checkout this company
Always shiny wheels.com
2019 Berkshire XLT 45A
2019 Jeep Rubicon JL
Sold prior to buying the Berkshire
2016 Ford F350 Platnium
2017 Heartland Landmark 365
1989 Winnebago Super Chief
Nightshifter is offline   Reply With Quote
Old 09-16-2020, 12:09 PM   #4
Those rubber inserts are specific to Freightliner. If you look at those openings in the aluminum wheels, they are a variation of the Freightliner logo. Those wheels go on all Freightliner chassis motor homes these days, and on a lot of their trucks. They are kind of attractive.
Gordon
Gordon Sick, Calgary
2015 Berkshire 34QS
The Manual I wrote for our 34QS:
https://www.forestriverforums.com/fo...qs-191578.html
Toad: 2019 Ford Ranger XLT 4x4; Formerly: 2005 Acura EL (aka Honda Civic)
gordonsick is offline   Reply With Quote
Old 09-28-2020, 10:40 AM   #5
Found them!
Old 10-05-2020, 04:14 PM   #6
RKNOLA's Avatar
There is a recall on those through Daimler Trucks/Freightliner: https://www.rvtravel.com/forest-rive...B6XKj29ixlAJWQ
Rick and Karen
2018 Berkshire XL 40C
2011 Honda CR-V toad FB
RKNOLA is offline   Reply With Quote
Old 10-05-2020, 09:42 PM   #7
I had that issue on a trip to Florida before i installed my TPMS. Luckily I caught it in the morning before we left. I removed the worn valve stem and added air to the tire. It was down to 80 lbs from the 100 psi original setting. I searched around the Jacksonville area and found a replacement valve stem. The original rubber was still on the old stem but not in the rim. I put the new stem on and reinstalled the rubber. It was installed backwards from the factory. I have a tpms now but check the rubbers every time I stop. I hope the repair from Freightliner will solve the problem.
valve, wheel
