Of course, you need to winterize your coach. I drain the fresh water tank, blow out the lines and put 12 oz of antifreeze in each drain. Then drain whatever residue is in the black and grey tanks.
Another winterize method is to charge all the lines with antifreeze, which I am sure you will be hearing advocates of this method.
Also make sure that you keep the batteries charged so that they do not freeze and burst.
Hank
Gale & Hank- 2012 Berkshire 390BH
I do it with jacks up.... With the air bags inflated, I built tower of wood (pressure treated) blocks that just fit under the jack pads with the air bags inflated. I then deflate the air bags and let the coach settle on the wood block towers.
This way, the jacks get to stay up, and it keeps weight off the suspension and deflated air bags.
X2!! I do the same but I just let the coach settle on the blocks as the air slowly seeps out of the bags.
Tom and Margaret
2014 Berkshire 390bh-60
