Strange Equalizer Problem
I was not able to auto level my new 2018 BK XL 40C. There is a slight slope on my lawn, but not anything I thought would be an issue.
After a couple of auto level attempts resulted in driver's side being too low, and the Excess Slope message, I thought I would manually adjust the jacks to get it as close to level as I could.
I tried to drop the jacks on the drivers side and raise the jacks on the curb side.
I lowered the driver's side, and there was no change on the level. I looked at the coach, and the driver's side front was down, but the curb side back jack was down.
I checked the pump and the colors of the control wire match the colors for the hydraulic fluid, LR Orange, RR Yellow. Those colors also match the on-line manual.
Any suggestions out there ? The tech at the dealer said he had a hard time with the auto level, but he thought it was due to the ground slope where the coach was parked.
I am tempted to switch the control wires for the RR and LR, and see if it helps. I suspect they are crossed in the control panel.
