Old 10-23-2020, 11:41 AM   #1
ernest917's Avatar
Stuck engine brake valve
Well this is something totally new....
This past Monday we drove about 70 miles from CG to Tyler, TX.... Everything was performing perfectly...
As I drove around the loop in Tyler I stopped at red lite and all was good... stopped at next lite and when lite changed I tried to proceed but had little to no power.... about 5mph tops....
Limped into a large Valero station and contacted Freightliner help line.. not much help there.... then called Tyler Freightliner Service center and had them read code.... said it appeared to be turbo overheating and suggested I bring it in....
Service center was 14 miles away so no way I could drive it there.... CoachNet RA to the rescue.... Massive wrecker showed up Tuesday AM and got us to Freightliner....
Yesterday, the problem was traced to an engine brake valve locked closed thus not allowing engine to power up... once valve was forced open full power was restored....
Ordered new valve BUT wonít be here until Monday AM so looks like we are in motel room 3 more nites....
AINíT LIFE GRAND!!!!!
ernest917 is offline   Reply With Quote
Old 10-23-2020, 06:59 PM   #2
Do you use the engine brake often? Looking for a reason for failure.
Trappfarmer is offline   Reply With Quote
Old 10-23-2020, 07:05 PM   #3
ernest917's Avatar
I do.....
Always in the mountains and usually in heavy traffic.... not so much wear/tear on my brakes ....
Gotta also remember that my coach is 12 years old (2008) so I imagine itís got lots of ďmilesĒ on it....
Old 10-26-2020, 11:02 AM   #4
I'm like Ernest and use my engine brake a lot.
I've found it to be reliable, but this does bring up some concern. For example, I will use it when there is light rain, which is not recommended by Freightliner, because I lose the anti-lock braking feature of the air brakes. I'll have to rethink my strategy on that.
ĖGordon
Gordon Sick, Calgary
2015 Berkshire 34QS
The Manual I wrote for our 34QS:
https://www.forestriverforums.com/fo...qs-191578.html
Toad: 2019 Ford Ranger XLT 4x4; Formerly: 2005 Acura EL (aka Honda Civic)
gordonsick is offline   Reply With Quote
Old 10-26-2020, 11:11 PM   #5
ernest917's Avatar
Gordonsick.....
I use my as much as I can to save my brake pads..... Been using it this way for the 9 yrs Iíve owned the coach so if it now need a new valve - so be it....
Iím so thankful it decided to give out AFTER Iíd made it to town and not out on the 70+ miles of two-lane back-country roads I used getting to town....
That would have REALLY made for a major problem for me.....
Old 10-27-2020, 10:26 AM   #6
Ernest,
Youíve got a 2008 Berkshire, so it might not have the same ISB6.7 Cummins engine that I have. From Cummins description of the engine brake on my engine, it works by changing the geometry of the turbines, which would be a pretty complex procedure, as I imagine it is done by a scrolling plate that pushes the turbine chamber in and out. It does provide a variable braking effect.
So, Iím wondering whether my engine brake would completely shut down my engine or just kill my turbo boost. Iíd be able to limp home without my turbo boost.
It sounds like your engine brake has a valve that opens and closes, and that might be on the air intake. I can see how that would really shut you down if it stayed closed.
I hope that some engine expert is reading this thread and will fill us in on more details.
óGordon
2015 Berkshire 34QS
Old 10-27-2020, 10:33 AM   #7
ernest917's Avatar
Gordonsick....
Actually I have a Mercedes turbo engine (which I LOVE) and you are correct - zero turbo and slowed to an absolute crawl....
Hopefully we will get our coach back today - had to order two parts and only one came in yesterday (sounds about right doesnít it) and fingers crossed that other comes in today....
Seven nites in motel with two dogs and wife - we are truly ready to get our coach back!!!!
Old 10-27-2020, 06:57 PM   #8
ernest917's Avatar
YEA!!!!!!!!!
FINALLY back in our coach and I expect to sleep sooo much better in my own bed!!!!!
Ended up replacing the engine brake valve which was stuck closed!!!!
Of course the part had to be ordered so that took additional time but eventually ďgot er done....Ē
Isnít it amazing how you miss ur rig when ur not in it!!!!
Old 10-28-2020, 04:46 AM   #9
glad to hear your back on the road. You made me call Coach net for a quote. I know it has saved you some money over the last few years
2012 390BH
dave-g is offline   Reply With Quote
valve
