Old 03-14-2017, 07:37 PM   #1
stephencamiolo's Avatar
Surge Guard displaying L1
We have a Surge Gaurd 50 amp hooked into our Berk. All has been well for 3 month. We came back from dinner and power is off. The Surge Gaurd display reads L1=Low RV off.
I've tried all the usual things:
-reset the breaker
-checked all fuses
-unplugged and replugged
Keep getting the same error.
Any ideas?
stephencamiolo is offline   Reply With Quote
Old 03-14-2017, 07:40 PM   #2
Too old to be too smart
SpringerPop's Avatar
Have you used a voltmeter out at the pedestal?
Maybe the SurgeGuard is doing its job. If the voltage drops below 102 volts for more than 8 seconds, you get an L-1 fault.
See this link for more details:
http://trci.net/media/36432/40240_tr...ng%20guide.pdf
Pop
Terry 250RKS, perfect for the two of us and the pups.
2000 F-350 7.3L CC/LB 4WD Lariat 3.73's
SpringerPop is offline   Reply With Quote
Old 03-14-2017, 07:41 PM   #3
No but the Surge Gaurd reads L1 as 90 volts which is under the recommended operating power.
Old 03-14-2017, 07:44 PM   #4
jk510's Avatar
You'll never figure out which is bad, the surge guard or the power itself, without a volt meter
Joel K
Southeast AZ
2013 Coachman Mirada 29DSSE
jk510 is offline   Reply With Quote
Old 03-14-2017, 07:48 PM   #5
Kanadian Kamper
kenandterry's Avatar
That's right....90 volts is way low.
Get your hands on a good volt meter.
Ken and Terry
2018 Sunseeker 2430S with Trekker cap
and only rarely pushed by our 2017 GMC Terrain toad (4 wheels down)
Former Georgetown 330TS owner for 10 years with more mods than I can count.
kenandterry is offline   Reply With Quote
Old 03-14-2017, 07:57 PM   #6
Dragonship Captain
Oscarvan's Avatar
Does it reset and go through the 2 minute plus countdown when you unlug/replug it?
And oh yeah, get a volt meter.
Read about our 2017 38A: https://dragonship.blog/
Oscarvan is offline   Reply With Quote
Old 03-14-2017, 08:07 PM   #7
After unplugging it goes through the 2 min cycle and then gives the error. I agree with the voltmeter. I have one in the toolbox in KY. Unfortunately we're 800 miles apart. LOL I'll be buying a new one tomorrow. I'll run the gen tonight and have the pedestal checked in the morning
Thanks everyone
Old 03-15-2017, 01:05 PM   #8
Swampy's Avatar
Thanks everyone
FWIW, Walmart has a nice digital multimeter for around $20 for a few $$ more you can get the set with the non-contact voltage sensor and the outlet tester. It reads as well as my Fluke does.
......... Swampy
Swampy is offline   Reply With Quote
Old 03-15-2017, 01:55 PM   #9
7 Year Class A RV'er
If it's suddenly giving the error, my bet is the surge guard is doing its job. Talked to the campground? If lots of folks are running electric heaters it could be pulling the voltage down.
2015 Legacy SR340 360RB
Old 03-15-2017, 02:15 PM   #10
Dragonship Captain
Oscarvan's Avatar
OTOH, I have a booster/monitor and THEN a Surge Guard. The other day it was claiming one side was low and the booster was perfectly OK with it all......
It didn't shut anything down however.
So, maybe they do see things that aren't there......
Old 03-15-2017, 02:17 PM   #11
...far N Georgia!
formerFR's Avatar
or you could just try the 30a side and see if it works...
formerFR is offline   Reply With Quote
Old 03-15-2017, 04:41 PM   #12
Thanks everyone!
The Surge Gaurd was correct Leg 1 of the 50amp service was only putting out 90 volts. Electrician confirmed and had to fix the pedestal.
All's well now
Old 03-16-2017, 11:10 AM   #13
Dragonship Captain
Oscarvan's Avatar
Cool, it did the job it was paid to do! Possibly saved you from further damage although you will never know!
Old 03-16-2017, 12:39 PM   #14
DAISY BOYKIN's Avatar
Saved yo can
It does pay to have a good surge protector! I had the same problem 2 years ago in a campground just south of Cincinnati. Voltage dropped to
102 VAC, surge protector shut all down. Moved to a different pedestal all was ok.
I have a dedicated volt/ohm Fluke meter in my camper, It stays there.
Sid & HRH MISSY, SHIH TZU
2019 WILDCAT 28 SGX
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2019 41 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 03-16-2017, 09:44 PM   #15
You can't go wrong with a Fluke! They're top-tier.
Mine stays in the truck.
Pop
