Originally Posted by giltbut4given
Thanks my friend, I'm new at all this, have a great day!
Just so you also know, they will suck your batteries down, only use them when you are plugged in with 110v or in your case you might have a generator which would be fine. Glad I could help. I park mine in my driveway plugged in and do not winterize, but I also leave a 1500 watt heater plugged in. It has been 22 degrees here and in my basement my remote stat says 55 degrees. I also put water in all tanks seams to me when the tank heats up it helps hold it down there. But they are still safe to use even empty..
