Old 01-12-2017, 03:39 PM   #1
Tankless Water Heater no Hot Water
Recently new to 2014 Class A RVs Recently purchesed a Used Berkshire 360QL unit with Tankless Water Heater issue....won't produce any hot water. Any suggestions would be appreciated. Gerard Systems GSWH-1
DontheRVDude is offline   Reply With Quote
Old 01-12-2017, 04:01 PM   #2
northstar1960's Avatar
make sure the water valves are in the correct position, gas on , switch on , faucet on
northstar1960 is offline   Reply With Quote
Old 01-12-2017, 04:08 PM   #3
They have been know to have a valve stick, is there a E1 error code at your display board? Mine did that and had to actually hit it to unstick it as per the manufacturer.
dblr is offline   Reply With Quote
Old 01-12-2017, 06:11 PM   #4
There are quite a few threads on here about that as well and I'm sure one of them will have your answer. Might even be as simple as the reset button which I'd fairly sensitive. Sometimes it is a matter of enough flow and pressure. Lots of folks don't use the pressure restricting device on the supply line and take the restrictors from the faucets. As mentioned earlier it may need just tapped. Also, they're susceptible to air lock and it's important to bleed out all the lines, including outside shower and washer/dryer ones before putting it on. Factory says they can air lock pretty easily those initial hook ups.
2016 Berkshire XL 40A towing 2020 Jeep Wrangler unlimited.
Prior to this Jayco fifth wheel: 24' Eagle, 30'Designer, and 40' Jayco pinnacle.
Igave is offline   Reply With Quote
Old 01-12-2017, 06:57 PM   #5
Don't forget, you can call the Gerard company and talk to there Tech Support, they have been very helpful in the past.
Bill
2015 Charleston 430RB
Billr is offline   Reply With Quote
Old 01-12-2017, 07:43 PM   #6
tmmar's Avatar
There is a triangular piece of metal on a short arm that is in the exhaust for the water heater. You can see it from the outside and it is called a 'sail switch'. You can move it back and forth a little to make sure that it moves freely. That needs to move to allow the water heater to fire up.
Tom and Margaret
2014 Berkshire 390bh-60
Old 01-12-2017, 09:50 PM   #7
Dragonship Captain
Oscarvan's Avatar
Not only does it need to move, the switch it operates needs to work. Multimeters are a wonderful thing.
Read about our 2017 38A: https://dragonship.blog/
Oscarvan is offline   Reply With Quote
Old 01-13-2017, 04:38 PM   #8
No hot water
I have had to jiggle the wire harness on more that one occasion to get the circuit board to kick it. It's a pain in the "butt" but happens occasionally.
Robertpaul is offline   Reply With Quote
Old 01-13-2017, 06:04 PM   #9
DouglasReid's Avatar
You did not say how you are operating the water when wanting hot water. You have to turn on the hot water ONLY at first until it get hot. The system needs to sense the water flow before it begins lighting and heating the water. Then you can add cold water to adjust the temperature.
It took s a bit to get used to it when we first got ours but now we love it, and it too is a Gen 1 unit.
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 01-18-2017, 08:52 AM   #10
muddyrode's Avatar
MR Reid nice looking camper you got there
but as you it took some getting use to but now we love ours also
2016 SANDPIPER 35ROK
2013 Silverado Duramax 3500HD DRW LB
Stop worrying about the potholes in the road and enjoy the journey
muddyrode is offline   Reply With Quote
Old 01-18-2017, 12:37 PM   #11
We like the looks of your camper as well.
We have owned a couple before this one and have seen many floor plans since purchasing this one and still keep coming back to this liking it better than anything else we see.
Old 03-29-2017, 02:42 PM   #12
WinstonSailor's Avatar
We use a routine of filling the kitchen sink, for dishes, with hot water which starts the tankless, and gets it hot without wasting the water, or the grey tank space.
WinstonSailor is offline   Reply With Quote
Old 03-29-2017, 03:41 PM   #13
BamaBob's Avatar
Or....you could install one of these babies
Next round of mods...the kitchen sink gets one!
RV – Aqua View, Inc.
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 03-29-2017, 04:50 PM   #14
Kenny kustom's Avatar
" simply attach to the non pressurized side of the fresh tank" Lol!!
2017 Dynamax Isata 4
Old 03-29-2017, 05:13 PM   #15
RKC02's Avatar
Not only does the water heater have to sense the water flow, there must be at least 1.5 to 2.5 gallon per minute flow rate (learned the hard way mine wanted 2.5 gpm).
Once I upgraded to a full-flow water pressure regulator (initially had the cheapy Camco), the water heater has been running like a champ!
2014 390RB-60 "The Shire"
RKC02 is offline   Reply With Quote
Old 04-04-2017, 10:51 AM   #16
Where are the temperature sensors in a berkshire 38a. We have found one in the bedroom, but there must be another one in the living area. We have not found it/them
Bellaboo is offline   Reply With Quote
Old 04-06-2017, 11:19 PM   #17
Dragonship Captain
Oscarvan's Avatar
Best I can tell it's in the thermostat itself, but I could be wrong.
heater, hot water, tank, tankless, water, water heater
