From the Michelin site- care of RV tires-
2. When you’re not using your RV, tire storage matters. How you treat your RV tires when you’re not on the road can have a significant impact on their lifespan and condition. When a tire is not given the opportunity to “exercise” regularly, it can begin to age prematurely if a few important storage recommendations aren’t carefully followed. Prior to acquiring your MICHELIN® RV tires, rest assured that they’ve been properly stored. MICHELIN® Commercial Service Network Dealers are held to specific tire storage standards and are regularly audited. All tire inventory is kept out of sunlight and away from any artificial sources of ozone. You should do the same. If your RV is kept outdoors, cover the tires to block direct sunlight. And, if kept in a garage or other covering, make sure it’s not a space shared with frequently used motors, generators, or transformers (including welding equipment). When you store your vehicle, it’s important to place a barrier between the tires and the concrete surface. Plywood is perfectly acceptable, as are rubber mats or even specialized plastic blocks. Before you park your RV in storage at the end of a trip, take the time to carefully clean the tires with water and a mild detergent, and then inflate them to the maximum pressure indicated on the sidewall. Before taking your RV on another trip, just be sure to follow the steps previously covered to determine the proper inflation level for the planned weight load. Lastly, if you plan to store your RV for longer than three months, you should consider taking it on a short monthly drive. This allows heat to build up within the tire and gives it the right amount of “exercise” to ensure you’re getting the most life possible out of your tires.
2012 390BH
