There are a few locations that the wall covering is being slide and causing separation, any ideas how to repair this? I was thinking a section of quarter round wood or cut and inject to glue to reattach it?
WD,
you can try using heat and smoothing out the bubbling and wrinkles. Our parts dept might have some seam tape you can purchase. Their number is 574-522-1747
WD,
I don't believe so, the heat kinda reactivates the glue and makes it adhere to the surface. you can try to smooth it with a bondo or body filler spreader.
