Old 07-27-2017, 10:51 AM   #1
ernest917's Avatar
Wiring Harness Issue
FYI: Berkshire owner info -
I just had to replace all wiring harnesses for all my gauges.... If you lift that removable section on the dash and you have WHITE wires running all over in there, you need to be aware that they are suggesting you replace them with newer heavy duty black wiring harnesses...
Reason - white wires tend to loosen at plug ins which causes gauges to go nuts (my air pressure gauges started showing ZERO air pressure)...
Quick, easy fix tho.... Just thought u might want to know this....
ernest917 is offline   Reply With Quote
Old 07-27-2017, 11:28 AM   #2
What year coach and who is suggesting they be replaced?
teamromano is offline   Reply With Quote
Old 07-27-2017, 11:36 AM   #3
ernest917's Avatar
Mine is an 08 and FL service center tech contacted FR help center and that's what he was told.... In newer rigs, this may have already been addressed....
Old 07-27-2017, 11:38 AM   #4
ernest917's Avatar
That's why I suggested u look to see if wiring is white or black... Replacement wiring is black with upgraded plugs on the ends....
Old 08-01-2017, 05:54 AM   #5
mdr
I have the same white wires going to all of my gauges. Was there a part number from FR? What was the cost? Thanks for the heads up...
mdr is offline   Reply With Quote
Old 08-01-2017, 07:31 AM   #6
ernest917's Avatar
I miss spoke in earlier post - tech called the Freightliner Help line NOT the FR one.... My bad....
Each wire had its own part number and I believe there were 8 different wires.... Parts cost was not bad at all - $160.00...Labor was $257.00.... So got it done for a tad over $450.00.... BUT all gauges are working perfectly now....
I'd give the Freightliner Help Line a call and they can tell you all parts numbers.....
Old 08-01-2017, 07:33 AM   #7
mdr
Thanks. You had yours swapped at a FL shop?
Old 08-01-2017, 07:35 AM   #8
ernest917's Avatar
Yes - in Bangor, ME....
Old 08-01-2017, 01:28 PM   #9
EJM4's Avatar
MDR - I believe he means Freightliner when using FL, not Florida.
Earl
2013 Berkshire 390BH / 360hp
EJM4 is offline   Reply With Quote
Old 08-01-2017, 01:34 PM   #10
ernest917's Avatar
Correct .... FL = Freightliner; FR = Forest Rivet
Old 08-09-2017, 11:04 AM   #11
mikeborny's Avatar
I had my dash gauges go crazy driving to elkhart Sunday! My ABS light came on, check brake warning, check engine warning, check transmission warning. Both RPM and MPH gauges went to zero then back again. Is this the same issue?
mikeborny is offline   Reply With Quote
Old 08-09-2017, 01:59 PM   #12
ernest917's Avatar
That's the issue.... Mine effected my ABS and air pressure gauges.... No problems since new wires....
Old 08-09-2017, 02:00 PM   #13
ernest917's Avatar
Do u have white or black wires???
Old 08-12-2017, 10:21 PM   #14
mikeborny's Avatar
I checked today and it looks like black wires!
Old 08-12-2017, 10:37 PM   #15
ernest917's Avatar
You should be good then.....
Old 08-12-2017, 10:42 PM   #16
ernest917's Avatar
BUT - sounds like you may have an additional "something".....
wiring
