Originally Posted by rvflyer57
The same issue can be found with the 11 cf unit installed in the MiniLite series. The one in my 2513s was poorly installed but not to extent yours was. See the MiniLite 2511 forum discussion on this very issue.
Rockwood really screwed up the framing around these fridges. I have a 2511s and fridget is framed out and sits the slide out. Same thing happened. Fridge tilted and I could even shut the fridge door without it smacking the wood frame. The dealer fixed it right away under warranty. The had to take out the Fridge and rebuild all the internal framing. Other than scratching my floor and leaving a mess, they did a great job and so far so good. They say the framing from the factory was a mess. I had the same problem with a drawer in our bedroom - that goes under the cabinet. That framing was bad. I had to to take out the drawer and fix myself. Yes, there are several threads on this in the 2511s conversations. Good luck
