Old 01-19-2021, 10:33 PM   #1
Angry 12 Volt Fridge Woes
My Furion 12 volt fridge went out 8 weeks ago, and received a GE 12 volt fridge as a replacement today. I think the GE replacements are not much better, had it installed today by the local dealer. Waited the four hours before turning it on like it says in the manual, and guess what. You guessed it it won't turn on, I swear if they tell me tomorrow that I have to wait another 8 weeks for a replacement I'll jump on someone's head. They have me over a barrel, as I am in Quartzsite till March, just as a side note it is still under warranty.
My unit is a 2020 Alpha Wolf 26RL-L
JoeMic is offline   Reply With Quote
Old 01-19-2021, 11:11 PM   #2
We always wait 12 to 24 hours before turning a frig on.
Ram 2500 / Surveyor 251rks
debit is offline   Reply With Quote
Old 01-19-2021, 11:58 PM   #3
Does that wait apply to newly-installed refrigerators? What is the point?
- 2016 Ford F-150 SCrew Lariat 4x2 3.5L Ecoboost, 1700# payload
- 2020 Rockwood 2507S
chriscowles is offline   Reply With Quote
Old 01-20-2021, 12:24 AM   #4
I always thought it was required if the unit had been on its side.
Are you plugged to "shore power".
Old 01-20-2021, 12:38 AM   #5
Yes, that is true. If the unit was always upright or at least upright for 12 hours there should be no issue. If it was laid on its side then there is an issue with the compressor oil getting into the coils. It needs time to drain back to the bottom of the compre.
I just had a new fridge installed at my house. Was plugged in immediately. Iím sure it was never on its side....
2016 Siverback 33IK, Towed 40K+ miles
Andersen Ultimate Hitch
RadMini Stepthru eBikes
Old 01-20-2021, 12:47 AM   #6
The thing that worries me is the light does not turn on when the fridge door is open, and on the manual it says to wait 4 hours which I did, because when they installed the fridge, it had to be placed on its back to mount the mounting brackets. So do I turn it off and wait, or leave it on.
Old 01-20-2021, 01:21 AM   #7
Well, maybe you are ok. If the light does not turn on it sounds like it is not getting power. Turn it off (may not really be on) and wait 12 hours or so since it was on its side.
You need to find where it is connected to the battery. Sounds like it is not connected or a fuse or circuit breaker is blown. Does it connect thru the dc side of your breaker panel? I would imagine it would have a pretty good sized fuse or breaker.
Old 01-20-2021, 01:40 AM   #8
The mechanic that installed it said power was getting to it before he installed it. I even checked the fuse on the 12 volt side and swap it with another 15amp fuse. So I assume power is getting to it. I've turned it off and will wait till late morning.
I just want you all to know I appreciate your help.
Old 01-20-2021, 08:01 AM   #9
It sounds like a power issue to me. I would check for power at the refrigerator. If you don't have power there, check the line coming out of the fuse panel. If you have power there then the fun begins, trying to trace the wire to isolate the problem.
Another thought, I've seen posts where someone said the fuse panel wasn't labeled correctly so you might want to check every fuse.
Hope it's that simple.
EddieL is offline   Reply With Quote
Old 01-20-2021, 08:08 AM   #10
Use a volt meter make darned sure it is getting power.
I thought the wait time and laying on side issue was only for evaporative ammonia refrigerators?
Aren't 12v units regular compressor types?
TT - 2021 Rockwood 2608BS
TV - 2020 F-250 XLT 4WD SRW 6.2L gas
mac1_131 is offline   Reply With Quote
Old 01-20-2021, 09:06 AM   #11
It's a generally accepted practice in the HVAC field, if a compressor driven cooling device is laid on its side, it should stay in the upright position for 24 hours (or as long as it was on its side) before turning on.
Yes, the newer 12v only R/V refrigerators are compressor type.
Days Camped: '18=51 '19=58 '20=110 '21=60
Old 01-20-2021, 07:10 PM   #12
If it has power you should hear the compressor running?
markb422 is online now   Reply With Quote
Old 01-27-2021, 06:17 AM   #13
The power problem could be a ground (battery negative pole) issue.
2018 Surveyor 264RKLE
Retired
Location depends on weather and state plandemic rules.
Most coincidences are carefully planned
Jeffjeeptj is offline   Reply With Quote
Old 01-27-2021, 06:55 AM   #14
FrankG's Avatar
Yep, that was my thought, after reading through a few posts. If it is a wiring Issue (or voltage issue) don't throw away the first refrigerator.
2021 Surveyor Legend 19RBLE
2018 Haulin 6 x 12 Cargo Trailer by Forest River
2017 Laredo 325RL Sold
2016 Vengeance 29V Sold
FrankG is offline   Reply With Quote
Old 01-27-2021, 05:25 PM   #15
Make sure the frig is plugged in. Donít ask how I know to check this first.
Aspendog is offline   Reply With Quote
Old 01-27-2021, 05:40 PM   #16
Flybob's Avatar
The waiting has nothing to do with the fridge not turning on. It is simply to let the oil and refrigerant drain back down into the compressor so you don't damage it. Not familiar with the GE product, does it have an off position on the thermostat.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
12 volt, fridge
