Originally Posted by REL
I'm getting a 12 volt tv for the bedroom. I would like to tap into the bathroom power since it shares a common wall. Power right now to the bathroom switches serve 2 led lights and the exhaust fan. The tv draws 4 amps. Anyone see any issue with doing this?
Looking at the image, I can't tell the physical orientation of the switches. There seems to be six connections. It appears that black is the unswitched hot for two switches and white+purple are the switched hot for each of two fixtures. White is apparently the ground return at both switches. Not sure why it would be at the switches unless they have indicator lamps.
Just an educated guess, but it looks like you could remove the Buchanan connectors and replace with wire nuts on the black and white connections and have unswitched 12v service for the TV on the other side of the wall.
HINT: Don't make the outlet on the other side directly behind this one--there may not be clearance for both. Offset it a bit.
