06-04-2021, 11:03 AM
120v/LP Dometic RM2551 on 19 geopro fbs
My fridge isn't working on 120v or LP gas. On gas, the pilot lights and the burner gets hot but the fridge doesn't get cold.
On 120v, the burner also gets hot but the fridge doesn't get cold either. I tested the AC outlet, works as it should and is reading 120v. I then unplugged the heating element and the control board prongs are also reading 120v. Heating element reads 82 ohms of resistance so I don't think it's that. What else do I check?
06-04-2021, 11:14 AM
It takes mine about 24 hrs to get “fridge temp” cold. Maybe give it more time? It also has to be level.
I haven’t been everywhere, but it’s on my list.
2021 Geo Pro G16BH
2012 Nissan Armada 4x4 Platinum
06-04-2021, 11:28 AM
Thank you so much for your response. I tried with LP for 24hrs and Ac for 24hrs. Still doesn't get cold. Camper is level as well
06-04-2021, 11:34 AM
I had the same issue last year on my Geo pro. The dealer had it a week after performing several tests as requested by Dometic. A new fridge was authorized and installed. Waited 3 months for the fridge. Bought a lot of ice that summer.
06-04-2021, 11:39 AM
Ugh that sounds awful! I'm really hoping it's not that.
06-04-2021, 11:42 AM
Agreed.
2021 Geo Pro G16BH
06-04-2021, 05:28 PM
Dometic
Just a shot in the dark. Is the thermistor connected and properly adjusted?
06-04-2021, 05:42 PM
Yeah I slid the slider as far up as it can go. Still nothing. Only thing left that I can think of is burping it but that's a lot of work! I wonder if there is a way to charge it? That way if there is air in there, it'll be pushed out. Idk
06-04-2021, 07:09 PM
There was another thread recently regarding absorption refrigerators that had set idle for an extended period. The problem was that the mix thickened or gelled. The solution was to vibrate the tank with an orbital sander. (The description of the problem and solution were much more elegant than mine.)
Larry
06-04-2021, 07:36 PM
Trailer Park Supervisor
Did it ever work? I had a bad A/C unit on my GeoPro (blew air, never got cold, something was wrong with compressor or refrigerant) right from the get-go, Airxcel did a warranty replacement. Wouldn't be first time they put in a bad appliance.
Yes, I drink the water!
06-04-2021, 08:31 PM
May have the answer.
Mine was doing the same thing about 2 weeks ago. Lots of ice at camp. Called in a mobile tech who came to the house. He said everything checked out OK except he did not have the ability to check the refrigerant gas. Took the trailer to an RV refrigeration guy. He stated the system was “over charged” so he emptied the gas and put in new at the specified pressure. As an aside, I tried the above mentioned method of using a sander on the coils to burp the refrigerator. Waste of time. Refrigerator is now working great on both electric and propane. My unit is also a 2551. Today I added the dinosaur thermistor to make the fridge colder. Results on this new add tomorrow.
06-05-2021, 03:52 AM
Following
06-05-2021, 09:01 AM
Checked this morning. Freezer and main refrigerator are operating within temperature specs.
Project done.
2021 Coachmen Spirit 1943RB
2021 Toyota Tundra Crewmax
