Old 05-24-2022, 12:08 AM   #1
12V oscillating fan?
Does anyone have recommendations for a 12V oscillating wall fan? It's like one that's effective, quiet, and not stupidly expensive, in that order.
TV: 2016 Ford F-150 SCrew EB RWD Lariat MaxTow
RV: 2020 Rockwood Mini-Lite 2507S
chriscowles is offline   Reply With Quote
Old 05-24-2022, 09:37 PM   #2
I mounted these USB fans in every berth in my motorhome. No regrets. Powerful, adjustable, low amp.Click image for larger version
Attachment 273901
Goatdog is offline   Reply With Quote
Old 05-24-2022, 11:15 PM   #3
Noise?
This one (very similar found on the same search as the description from yours) would work better for me because it's 12V.
https://smile.amazon.com/Electric-Co.../dp/B07PLF45KR
Old 05-25-2022, 07:56 PM   #4
larry2c's Avatar
I have a fan very similar to the one Chris linked to - seems to be lots of similar looking units on Amazon. Mine was noisy to me but I bought a rheostat so I could slow the RPM's and now I can sleep with it on when I turn it down low (it still moves enough air for me).
I just want to be outside!!!
'17 Salem Cruise Lite 210RBXL
'11 F150 5.0
Only one shedding mutt now RIP Yoshi
larry2c is offline   Reply With Quote
Old 05-25-2022, 08:05 PM   #5
That would work for me. Is it labeled or have you measured the amp draw? Does it oscillate?
I have a 120V 0.4A (48W) Hurricane wall fan. We use it inside but it's pretty noisy, even on its lowest speed. There's little difference in air flow at higher speeds. At 48W, the amp draw isn't too bad but my inverter would add another 9W (measured).
Old 05-25-2022, 08:19 PM   #6
We purchased a couple of battery operated fans that are quiet and do a great job. They are usb rechargeable which we prefer for boodocking.
2021 2205S Rockwood Minilite
2019 F 150 Lariat 3.5 Eco Fx4 Max Tow
Equalizer WDH, 1809 lb payload
flyflotrtim is offline   Reply With Quote
Old 05-25-2022, 08:20 PM   #7
How long does a charge last?
12v, fan
