Old 07-15-2024, 12:59 PM   #1
12V refrigerator blowing fuse
Why does my 12V refrigerator keep blowin the fuse?
Rodbreese is offline   Reply With Quote
Old 07-15-2024, 01:42 PM   #2
I'll bite, why does your 12v fridge blow a fuse? Are you angering it? (Sorry, I couldn't resist).
Fuses blow for only one reason, too much current draw. Is this a new problem, or has it always done this?
A couple of things to check off the top:
- how strong is your battery? If your voltage is dropping too much the fridge draws more power and can trip off the fuse.
- how heavy is the wiring back to the battery. The fridge does still draw a fair bit of current, and requires some pretty heavy wire. Mine is 30' away from the battery, so has a separate heavy gauge wire direct to the battery. If your wiring is too small, current (and heat) will rise and blow a breaker.
- If this is a new problem, and it was working well previously, there is possibly an electrical issue with either the control board or compressor. You can also check the fridge access panel to see if any critters have been lunching on the wires.
Post back with a little more information about when this happens and if there are any common triggers.
bankr63 is offline   Reply With Quote
Old 07-15-2024, 01:57 PM   #3
Post a LOT more information. Did your trailer come with the 12v fridge or was it a conversion?
Rockwood Ultra Light 2304DS, towed by 2018 Ram Cummins 2500 4x4
RobbieH is offline   Reply With Quote
Old 07-15-2024, 02:26 PM   #4
bikendan's Avatar
Yep, need more information.
FR's divisions probably install 4-5 different 12v only fridges.
Year, make and model number of RV
Make and model number of fridge
12v, fuse, refrigerator
