Old 07-09-2024, 06:56 PM   #1
12v refrigerator problem
2022 XLR MICRO BOOST 335LRLE with solar.
Last week we opened our camper to get ready for the weekend and noticed that the refrigerator was not cold. Spoiled some food in the freezer, not a big deal. Plugged the camper in to shore power and fridge came on and cooled down. Camped for the weekend and everything was fine. Unplugged from shore power and came back to check on things 2 days later and noticed that the fridge isn't working on solar. Solar readout shows full charge on battery.
burdawg2224 is offline   Reply With Quote
Old 07-09-2024, 07:10 PM   #2
bikendan's Avatar
Moved thread from the General Community Discussion section to the Appliances and Electronics sub-forum since the OP's questions are specific to Appliances and not general questions.
Old 07-09-2024, 07:12 PM   #3
I should add that it's a furion refrigerator. It sat from Memorial day weekend until father's day weekend and stayed cold on just the solar.
Old 07-09-2024, 07:12 PM   #4
Thank you
Old 07-10-2024, 05:05 AM   #5
After further research, I'm leaning towards the power inverter. Going to run so.e tests Thursday afternoon.
Old 07-10-2024, 06:04 AM   #6
For a 12 volt device? I thought the inverter is for changing the 12V to 120V?
2022 Rockwood 2511S
2018 F150 3.5 Crew Cab 4x4
Max Tow Package 1855 Lbs Payload
Husky CenterLine WDH
GolfingDave is offline   Reply With Quote
Old 07-10-2024, 06:38 AM   #7
If you have a Furrion 12VDC compressor fridge, then an inverter isn't involved. It runs directly on 12V battery power. Does anything else that uses 12V (such as lights) work when you're not on shore power? I ask because your problem sounds like the battery disconnect switch is Off. Solar is connected directly to the battery, so it would still show a full battery while the switch is Off, but your 12V systems would only work when 12V is being supplied by your converter from shore power.
2023 r-pod RP-192 with Beast Mode suspension
600W rooftop solar, 300Ah LiFePO4 battery bank, 2000W inverter.
Uses an electric coffee maker when boondocking.
"Never underestimate the power of human stupidity."
-Lazarus Long
jlankford is offline   Reply With Quote
Old 07-10-2024, 08:15 AM   #8
what Jlankford said +
disconnect switch may be BAD I had to wiggle mine to get it to work
replaced it and put it inside out of the weather
caould also be a 12v breaker near the battery
they got tiny buttons to push for reset.
Tarpon Springs FL
2022 Salem 24RLXL
Aussieguy is offline   Reply With Quote
Old 07-10-2024, 08:24 AM   #9
Thanks gor the reply, I'm going to check tomorrow afternoon.
Old 07-10-2024, 04:52 PM   #10
On A side note. The refrigerator light comes on but the fridge is warm. I will be checking if the lights in the camper are working.
Old 07-15-2024, 09:35 AM   #11
Had just the opposite problem with our furrion, fridge would not shut off Might possibly be related.
Did the normal internet search and found someone else experienced this. Replaced the On/Off/thermostat control switch and all is well. They sure use cheap switches and controllers on RV stuff.
NOBO 2023 20.3 Beast suspension, std. solar pkg
too many mods and repairs to list
4x100ah LifePo4
2019 Ford Expedition Max, payload ~ 1700
Former - 2019 NOBO 19.7
DES-1 is offline   Reply With Quote
Old 09-06-2024, 07:51 AM   #12
Update. It was just a bad battery. Sorry for the delay on the update
Old 09-06-2024, 08:16 AM   #13
Rhumblefish's Avatar
Thanks for getting back to us Burdawg. The 12v fridges are pretty power thirsty, and solar only goes so far in keeping the fridge cold till it starts eating into battery. How big are your battery and solar banks?
2022 Rockwood Roo 235S
15kBTU AC; 12v fridge; 1kW roof-mounted solar panels; 80 amp MPPT charge controller; 3,500w pure sine wave inverter; 30a automatic transfer switch; MicroAir EasyStart, 600ah Chins LiFePo; Honda EU2200i (with Hutch Mountain propane conversion kit) gathering dust in the storage unit.
Rhumblefish is online now   Reply With Quote
Old 09-06-2024, 09:04 AM   #14
If you list battery size, solar collector size and the fridge model number we can give you an idea of how long you can not plug into shore power.
The average rv is likely to be iffy for one night. The dealer should have explained that.
tomkatb is offline   Reply With Quote
12v, refrigerator
