Originally Posted by boondocking
Your bypass valves are not set correctly and the hot water is mixing with the cold water.
You are correct and you figured out what the problem is! I appreciate you responding to my post and supply the answer to the problem.
As for the propane side not working. I located the controller board. It was taped on top of the water heater. I unplugged the plug on it and reconnected it. It would then fire for as long as the spark igniter was sparking then go out.
One would think the thermocoupler was at fault. However in this unit per se there is no actual thermocoupler. The nearest thing I could figure is the spark igniter detects the flame. I removed it and cleaned the surface contacts up where it mounted and got rid of the lime scale. When I put it back together it fired and continued to heat after the spark ignition quit firing.
So I am good and appreciate your assistance and caring enough to respond to my post, Joe Schulte
