Closed Thread
Old 04-27-2020, 03:29 PM   #21
Mr. Dan's Avatar
Originally Posted by Nomore9-5 View Post
I'm going to assume you've checked and it's not a tripped breaker or fuse . You'll have to next determine test if there's voltage across the terminals of the heater element. If there isn't chances are the switch needs replacing or ( less likely - the thermostat or the contact it makes with the tank ( dirt / rust ?) may be the issue If there is my guess is the element is the culprit ( if you have a continuity tester you can test for this)
Please see post #20 right up there. ^^^^
Mr. Dan is online now
Old 04-27-2020, 07:26 PM   #22
Casino Camper
jughrad's Avatar
Check Heater Element
2016 Cherokee 264L (Rear Living)
2013 GMC Sierra Denali
jughrad is offline
Old 04-27-2020, 07:32 PM   #23
Mr. Dan's Avatar
Originally Posted by jughrad View Post
OP says it's working now. See posts above. ^^^^^^^
Old 04-27-2020, 07:57 PM   #24
Just as confused as you
Scrapper's Avatar
Originally Posted by pokey View Post
The electrical switch has been off for two days. I went out hit a reset button that seemed to not push in. Waited 30 minutes or so and it's working again.
The reset button is a bi-metallic switch so there isn't much movement to reset it.
Richard & Jill
Scrapper is offline
Old 04-27-2020, 08:10 PM   #25
Not a Suburban
Originally Posted by rockfordroo View Post
The reset is for your thermostats. You have 2, a 12VDC one that turns the LP burner on/off and a 120VAC one that turns the electric heating element on/off.
It may be that your T-stat is going bad. If you continue to have trouble, here are the Suburban PN's:
The first 2 are what you should have as standard. The next two are the hotter ones. I could only find one lower one; I THINK 120VAC.
Standard
232306, 130 deg, 120VAC
232282, 130 deg, 12VDC
Higher
232319, 140 deg, 12VDC
232317, 140 deg, 120VAC
Lower
520788, 120 deg, 120VAC??
But in the original post he stated it was a Dometic, not a Suburban.
Larry
Larry-NC is offline
Old 04-27-2020, 09:09 PM   #26
I thought that, too, but then went back and couldn't find again, so I posted.
Oh, well. Maybe it will help someone else.
2011 Traverse LT, 3.6L, FWD
rockfordroo is offline
Old 04-28-2020, 05:52 AM   #27
pokey's Avatar
I should have posted the model number to help figure out the issue easier. I was looking for what I could possibly check. Sorry!
Pokey
Permanent RV'er
2006 Cardinal 29LE
Why do today what you can put off until tomorrow.
Retirement life........
pokey is offline
Old 04-28-2020, 05:56 AM   #28
pokey's Avatar
Thanks for posting the thermostat PN's. If it does it again working after being off for 2 days the thermostat is more than like the issue.
Pokey
Permanent RV'er
2006 Cardinal 29LE
pokey is offline
Old 04-28-2020, 06:57 AM   #29
wmtire's Avatar
Hey guy's, My hot water heater quit working on electric. It works great using LP but wondering what to check to see what the issue is with it not working on electric. Thanks in advance for any help with this. It's a Dometic unit.
Thanks, Yes the switch is in the lower left corner. If it's the element would it still work on propane? It works great using LP. I just watched a video where one didn't work on LP and it was the circuit board.
It's been working great for 2 years now. It is an '06 model. I'm full time so use it a good bit. The switch is only at the hot water heater. The one for LP is inside.
Thanks, I'm plugged in to a 50 Amp pedestal and everything electrical works except the water heater. The heater doesn't have a 110 outlet to plug into. I just saw two reset buttons beside each other inside of the water heater. The one on the left doesn't seems to reset or push in at all. The one beside it the rubber cover has worn off and I pushed it also. I turned the switch back on at the heater and waiting to see if it'll work. If not it needs to be checked using a volt meter from the breaker and then to the wiring at the heater. I can use it on propane now, I'll just turn on as needed until I can find out the electrical issue.
Yes, the OP did post the wrong brand in their first post, which would/did confuse the situation. They did incorrectly identify it and say it was a Dometic, but then describes a Suburban in all the follow up posts.......so all the information/advice pertaining to a Suburban water heater is definitely applicable here.
I went ahead and added an edit note to the first post to correct this, should anyone in the future find this thread searching for a similar problem.
The member most likely has a Suburban SW6DE water heater, but can use this info below to correctly identify.
Suburban Water Heater (SW | V | SAW Models) The model and serial number information can be located by opening the water heater access door on the outside of your RV. The silver colored data plate with black printing is located on the right side of the metal control housing as you face it from the outside. The model number will be located on the top line of the data plate and will begin with "SW", "SAW" or "V". The nine digit serial number will be on the bottom line.
2011 Flagstaff 831 RLBSS
wmtire is offline
Old 04-28-2020, 07:51 AM   #30
Scrapper's Avatar
Which, in that case would make it a Atwood water heater.
Richard & Jill
Scrapper is offline
Old 04-28-2020, 11:48 AM   #31
pokey's Avatar
It's a Suburban 6W6 DE. I put a Dometic in by mistake.
Pokey
Permanent RV'er
2006 Cardinal 29LE
pokey is offline
Old 04-28-2020, 11:51 AM   #32
pokey's Avatar
The member most likely has a Suburban water heater, but can use this info below to correctly identify.
Thanks and yes I did say that is was a Dometic by mistake. It is a Suburban water heater 6W6 DE . From a reply below it possibly is or can be the thermostat at the heater. I found several for around $12. I'm going to replace it so it will eliminate that issue.
Pokey
Permanent RV'er
2006 Cardinal 29LE
pokey is offline
Old 04-28-2020, 12:10 PM   #33
wmtire's Avatar
Thanks and yes I did say that is was a Dometic by mistake. It is a Suburban water heater 6W6 EE . From a reply below it possibly is or can be the thermostat at the heater. I found several for around $12. I'm going to replace it so it will eliminate that issue.
I think you may have a typo. It may be a SW6DE
wmtire is offline
Old 04-28-2020, 12:56 PM   #34
pokey's Avatar
Thanks and it is the 6W6DE as I posted below. I did have EE and edited it.
Pokey
Permanent RV'er
2006 Cardinal 29LE
pokey is offline
Old 05-04-2020, 10:28 PM   #35
Seems it was just 2 hours and 16 minutes to fix itself again! Not a bad time!
Playing around seems to work often, and since it is a 120v circuit an electrician should handle this kind of problem if it persists!
ebergler is offline
Old 05-05-2020, 06:25 AM   #36
pokey's Avatar
It reset it's self I guess. Like rebooting a PC!
Pokey
Permanent RV'er
2006 Cardinal 29LE
pokey is offline
Old 05-05-2020, 07:58 AM   #37
Water Heater in Electric Mode
EDIT by site team: The member has a Suburban water heater, not a Dometic.
With a voltmeter check to see if voltage is present on the heater element. If no voltage it could be the thermostat that should be mounted on the water heater somewhere to keep it from overheating and overflowing. I had this problem on my water heater. Part was about $15 or so and easy to replace.
czachry is offline
Old 05-05-2020, 08:23 AM   #38
Mr. Dan's Avatar
6W6DE or SW6DE?
Old 05-05-2020, 08:55 AM   #39
pokey's Avatar
It's been working great since the issue. I am planning on replacing the thermostat because it is only around $15 and very easy to change out.
Pokey
Permanent RV'er
2006 Cardinal 29LE
pokey is offline
Old 05-05-2020, 09:15 AM   #40
I assume you know that the electric element is pretty slow.
The gas is likely 3x as fast. Maybe more.
When you know there will be a line at the shower, you can then turn on the convenient switch in the rv and use both.
When we do that our 12 gallon unit is virtually continuous.
tomkatb is offline
Closed Thread
heater, hot water, water, water heater
