Old 06-08-2023, 07:21 PM   #1
Ac control hard to turn
I have a Colman ac and the knob for the fan/ac is extremely hard to turn. Any suggestions on freeing it up?
Mountain Minstrel is offline   Reply With Quote
Old 06-08-2023, 07:33 PM   #2
bikendan's Avatar
Moved thread from the Tech and Repair section to the Tent Camper and Popup section since the OP has a popup and the a/c may differ from those in other types of RVs.
Sent from my SM-G781U using Forest River Forums mobile app
Old 06-08-2023, 08:00 PM   #3
Actually I no longer have a popup. What have now is a 97 mallard. I know this is not the correct forum for a mallard but I trust the advise I get here.
Old 06-08-2023, 09:01 PM   #4
bikendan's Avatar
Then you should update your profile or signature.
And you need to post make and model number of the a/c since your Mallard is an 26 year old non-FR product. Or post pics of the controls.
Old 06-08-2023, 09:36 PM   #5
Don't know where you started out, but you should probably be in the appliances and electronics section.
Have you tried removing the knob and cleaning it out? You could take the interior cover off and see if there is debris (dust, insects,...) blocking the mechanism.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 06-08-2023, 10:35 PM   #6
bikendan's Avatar
Reverse, I moved it from the A&E sub-forum because the OP listed a popup in their profile and hadn't updated it.
It's been moved back the the Appliances and Electronics sub-forum.
Old 06-09-2023, 10:42 AM   #7
Old 06-09-2023, 12:51 PM   #8
If you have the standard Coleman Mach ceiling A/C unit, here is the switch:
https://www.amazon.com/Coleman-67593...dp/B01MDPEB61/
You might want to pull the knob off and try electronics cleaner and/or lubricant spray. It is not very difficult to remove the switch so you are not doing it upside down. Just make sure to take pictures of the wiring before you pull any wires off.
NavyLCDR is offline   Reply With Quote
Old 06-09-2023, 03:37 PM   #9
Fixed. A little WD40 clears up the issue.
Thanks navy but I fixed it before I was your post.
Old 06-10-2023, 10:41 PM   #10
Thanks for sharing how you fixed it. It may help someone else in the future.
