Old 08-03-2021, 05:53 PM   #41
Geez, read the book folks. I thought mine was defective too till I read the manual. It's normal.
Sunseeker16 is offline   Reply With Quote
Old 08-03-2021, 06:34 PM   #42
lesptr's Avatar
This!
Itís by design.
2017 Coachman Chaparral 336TSIK
2015 F350 6.7
lesptr is offline   Reply With Quote
Old 08-04-2021, 08:05 PM   #43
Ac cycling
I have a Coleman 15k ac unit that was cycling cold then cool. Drooped the cover and Found the return air/ supply air separator board wasnít in correct position.
Put it back together correctly, works well. They make a Styrofoam insert that. Helps with air Flow and noise. Rv airflow is the name I think.
Mgwyn is offline   Reply With Quote
Old 08-04-2021, 08:28 PM   #44
I had the same short cycle problem with my dometic thermostat and ac in my A Frame. I replace the thermostat with the easy touch rv thermostat a few months ago. Been working fantastic, no more short cycles or leaving fan running.
My review is in the A Frame section on this forum.
i tried to insert link to my article, but Iím stupid, so just paste it,
https://www.forestriverforums.com/fo...ed-233451.html
Bill
Billk28078 is offline   Reply With Quote
Old 08-04-2021, 09:02 PM   #45
Trailer Park Supervisor
NJKris's Avatar
Bill, your link works fine.
Yes, I drink the water!
NJKris is offline   Reply With Quote
Old 08-05-2021, 11:13 AM   #46
Thanks kris, i can never figure out all them posting buttons and stuff.
Old 08-05-2021, 11:40 AM   #47
NJKris's Avatar
As you compose message, the little 'globe' with the chain link is what you click, then cut and paste link into it.
Old 08-05-2021, 07:19 PM   #48
RockyMountainMarty is correct. I had same issue and re-taped the return and supply plenum in the camper behind the air filter.
Fixed my issue.
TexasFive is offline   Reply With Quote
Old 08-12-2021, 11:31 AM   #49
If itís an analog thermostat change the thermostat
McFord94 is offline   Reply With Quote
Old 08-12-2021, 11:57 AM   #50
I put in 4 thermostats, they changed the ac unit 4 times, just leave the fan on low not auto. There is a company that makes a mod for air flow and says it helps with cycling, it's called RV Airflow Systems. I haven't tried it but looks promising.
wnew813 is offline   Reply With Quote
dometic ac trouble
