Old 06-22-2024, 09:24 AM   #1
Add house thermostat to roof AC
How do I add a house thermostat to roof AC?
I have an old-style bi-metal thermostat I want to use instead of the AC's temp sensor. I moved the knobs/controls to the wall but that took the temp sensor out of the airflow and to the wall. It still works but not as good, but that is not the question...
Is there a way to wire it in place of the temp sensor or do I wire new thermostat to turn on/off the compressor?
Unit is a Coleman Mach8 CUB
santasurfer is offline   Reply With Quote
Old 06-22-2024, 09:40 AM   #2
Rv thermostats are dc. Home units are typically low voltage ac. So not easy.
Newer rv thermostats are digital. Another complication.
Good luck.
tomkatb is offline   Reply With Quote
Old 06-22-2024, 10:18 AM   #3
I said old. It will work on DC.
I have a t-stat, looking for wiring help on Coleman only.
roo, roof, thermostat
