Old 04-23-2019, 06:18 PM   #1
Air conditioning leakage
This spring, after very heavy rainfalls, I've noticed a little water dripping from the screw covers of the inside ceiling panel of the air conditioner. If i remove the panel, it's collecting some water somehow and dripping out the screw holes. Not a lot, but enough to be of concern.
So i crawled on the roof thinking the drain holes on the pan were clogged, but after removing the shroud, everything looks great-- all the holes i see are clear. The rubber gasket on the roof is in like- new condition too, as is the styrofoam cover over the intake/ fan. I'm attaching some pictures for you. The camper is only 3 or 4 years old, so everything is still in good condition best i can tell.
Any ideas? Think it's just condensation when the weather suddenly turns cold after a cold front?
ID:	202623Click image for larger version
ID:	202624Click image for larger version
ID:	202625Click image for larger version
ID:	202626Click image for larger version
2016 Salem Cruise Lite 261bhxl
Ram 1500 5.7l Hemi Crew Cab 4wd
gspot01 is offline   Reply With Quote
Old 04-23-2019, 08:01 PM   #2
air conditioning leaking
I had water leaking from my air conditioner on a Keystone trailer. I took it in to the dealer and was advised the AC roof seal needed to be replaced. You may have a different issue causing the leak. Be sure to check your roof for possible tears to the roof membrane you may not be aware of. Those pesky limbs can do a lot of damage.
Famoussenior is offline   Reply With Quote
Old 04-24-2019, 10:39 AM   #3
If you've never tightened the hold down bolts, I suggest you snug them down a little. I believe the torque is about 45 in/lbs (~4 ft/lbs) so it's not very tight.
Gotta go campin!
Old 04-24-2019, 10:14 PM   #4
Iwannacamp's Avatar
Yeah...or a wire,trash, folded membrane, piece of wood, Coke can, torn/cut roof membrane you can’t see, etc. Have you removed the unit to look? Might just loosen and lay down and peek for issues. I would lay something dark on the bed so you can see if it falls out when working on it. Gaskets are pretty cheap.
Need to fix ASAP will rot quickly.
Good luck buddy.
2017 Puma 297RLSS
leak
