04-08-2021, 09:14 AM
Anode rod leaking
Put the anode rod back in after dewinterization. Plumbers tape and not cross threaded as it turned several times by hand and not over tighter, just snugged tight. But something went south, as it is leaking, is there a way to fix this without replacing the whole thing. I ordered a new anode rod.
2023 3/4 ton Chevy Silverado Diesel
2024 Grand Surveyor BHXL 240. 400 watts solar, 2000 watts pure sine inverter, 30 amp controller and remote 2-100ah LiFeP04 in parallel
04-08-2021, 09:16 AM
Try adding a couple of more wraps of teflon tape and try again.
2011 Flagstaff 831 RLBSS
04-08-2021, 09:21 AM
I think I would pull the rod and take a thread chaser (tap) and clean the threads on the tank if you don't have a tap a wire brush will work. then reinstall with teflon tape or like I use pipe dope and tighten.
Retired Navy
2016 Flagstaff 26 FKWS
04-08-2021, 09:44 AM
I was thinking pipe dope but concerned with toxicity being a drinking supply or am I worrying for nothing?
04-08-2021, 09:53 AM
Boss Ox & Drovergirl
The pipe dope won't hurt the water.
Mine did the same thing, and as SeaDog mentioned, I chased the threads, big honker of a tap for the female side!
Or use a small steel wire brush (toothbrush size) or better yet a dremel with a small wire wheel will do the trick. Extra teflon tape and don't overtighten!
Good luck.
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2016 GMC 3500HD Duramax dually
1992 Goldwing Aspencade
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
04-08-2021, 10:24 AM
Originally Posted by SailorSam20500
X2 - On the recommendation of nomad297, I used this on my quarter turn low point and fresh water drain valves and on my anode rod (for the first time - had always used Teflon tape).
MHO is that the anode rod pictured by the OP needs another grunt of tight.
04-08-2021, 10:26 AM
Clean the threads and reapply Teflon Tape. (recommended by the water heater manufacturer)
You said you didn't overtighten but did you tighten enough?
Pipe threads have tapered mating surfaces and you do have to use enough force to keep it from leaking.
You simply may not have tightened enough.
04-08-2021, 10:37 AM
This is aluminum and aluminum and I do not get along My first motor cycle at the age 8 had an aluminum head. I had to change out the spark plug and stripped it because I tightened it to much. Flew down to Florida in the 80's, hated flying so much I bought a junker car and drove back. Loved the car so I rebuilt the motor, even using a torque wrench I tightened the head bolts incorrectly on the aluminum head and warped the head.
I have nightmares when I have put in the anode rod about over tightening it and stripping put the threads on the hot water heater
Have worked with heli coils also and hate them just as much. So what would I do if I over tightened the anode rod????
04-08-2021, 10:58 AM
The suburban water heaters anode rod/drain port threads aren't aluminum......unless they changed very recently.
That's why these ports threads rust over with the anode rod removed and you sometimes have to clean them
04-08-2021, 11:01 AM
Not sure what you are referring to?
The anode port is steel as is the threaded part of the anode rod.
Spark plug threads are not tapered and a completely different ballgame.
You'd have to be a gorilla to strip the tapered pipe threads on the anode/port.
04-08-2021, 11:07 AM
And in addition to my previous post and 5pickers above....the OE Suburban anode rods do not have aluminum threads
04-08-2021, 11:30 AM
Yes I have given it a 2nd look and was incorrect.
_ i will go out after work and try to tighten it more
04-08-2021, 11:38 AM
Tap for Suburban W/H
Tap size is 3/4-14 NPT when you buy one! Youroo!!
04-12-2021, 11:53 AM
Be careful using pipe dope. Electrical continuity must be maintained between the anode rod and the tank. Might want to measure the resistance between the anode rod plug and tank with a meter and make sure the resistance is low.
04-12-2021, 12:01 PM
I had same issue. Finally used a tap to clean the threads. After that, all was well.
https://www.amazon.com/Drill-America...657653812&th=1
2015 silverback 31IK
2023 f350
04-12-2021, 02:06 PM
All well as I took it triple up the tape and tightened it down. I do not recall having to put that much tape on it and tightening it up that much
04-22-2021, 05:58 PM
4 wraps of tape standard
