Old 06-25-2018, 03:03 PM   #1
Antenna won't turn
We have a 2017 Vibe 268rks and the antenna quit turning. You can pull the collar down and turn it but it turns freely without turning the antenna. Any help would be greatly appreciated.
Ls15sl is offline   Reply With Quote
Old 06-26-2018, 07:26 AM   #2
SeaDog's Avatar
Welcome to the forum its a great place to get your questions answered. It sounds like the pin has broken or come out of the slot take the operator apart by first removing the handle and you may be able to fix it.
Retired Navy
2016 Flagstaff 26 FKWS
Old 06-26-2018, 09:05 AM   #3
Wanna Be Camper
SaskCampers's Avatar
Have a look at this video
John & Deb
2011 Flagstaff V-Lite 30WRLS
Old 06-26-2018, 09:29 AM   #4
Flybob's Avatar
If the set screw in the crank gets loose, the crank will slip down then the rotating ring will also slip down and not engage the rotating gear. Loosen the set screw and push the crank back up.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-27-2018, 05:53 PM   #5
Thanks for all the help. The tabs on the piece that you turn were broke off.
antenna
