Any camera will "go onto" an E Pro 19fd. Any camera will "go onto" any RV. If your trailer is pre-wired for the camera it will probably have a Furrion sharkfin. If you select a different camera you may have to trade out that sharkfin or get an adapter. Most camera mfgs. make an adapter for that purpose.
Lots (and lots, and lots, and lots) of posts about camera's on this forum. There are much better cameras available at a much lower cost than Furrion. The consensus here seems to be the Haloview brand.
And you don't want a backup camera. You want an observation camera. A backup camera (like you see on Amazon) is made specifically for backing up - - lower frame rates, (usually) lower resolution. Over a few miles per hour and they begin acting up. An observation camera is capable of producing non-flickering, non-cutting out, video at highway speeds so you can see what's behind you as you drive.
